Old 11-01-2006, 10:03 AM   #1 (permalink)
01001010's Avatar
Gallery: 15
Default 9" Tread
I'm looking for an MT with a 9" tread. There are a parks down here that require this in order to get their permits.
Do any of these have a 9" tread...
  • 267/75/16
  • 255/85/16
  • 285/75/16
JC...
Old 11-01-2006, 10:29 AM   #2 (permalink)
01001010's Avatar
Gallery: 15
Ok scratch the 285...just found out it has 9.5"
JC...
Old 11-01-2006, 12:37 PM   #3 (permalink)
rbutler's Avatar
I think it will depend on the tire manufacturer. Of 4 that I checked, only Sumitomo lists tread width in their specs (BFG, GY and Toyo do not).
Sumitomo lists the 285/75/16 Durango M/T as 8.9 in. tread width - less than the 9.5 for the tire you checked. Your other two sizes are 7.4 (255/85) and 7.6 in. width.
In your case I think it will depend on who is measuring the tire (since someone at the park will likely be checking). Sumitomos seem to have a wide shoulder that they are not including in the tread width measurement. The section width of the 285/75 is 11.3. I could see someone including the shoulders and disqualifying this tire (the 255/85 might be safer).
http://www.sumitomotire.com/catalogs/
passenger & light truck catalog
'04 Freelander HSE Alveston Red
'05 LR3 SE Tonga Green
rbutler is offline   Reply With Quote
Old 11-01-2006, 02:59 PM   #4 (permalink)
01001010's Avatar
Gallery: 15
Butler, you're right...the tire I measured in 285 was a BFG MT. Very square tread.
I would be looking for a BFG MT. I was making a few phone calls too and I was told that it would also deopend on the widt of the wheel it goes on. In this case, I plan to put them on NATO wheels.
JC...
Old 11-03-2006, 08:05 AM   #5 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
9" tread? Do you mean the tyre width?
Seems like an odd requirement. Anyhow if you do then there are 25.4mm to the inch.
So a 285/75 tyre has a 285mm width or (285 / 25.4) 11.22"
A 9" wide tyre would be 228.6mm, so only 225's and smaller will be acceptable.
The Best 4X4XFar
Old 11-03-2006, 08:09 AM   #6 (permalink)
01001010's Avatar
Gallery: 15
Yep..I do mean tire width. I have 245/75/16 but they are 8.5" wide, and the park rangers dont let anything slide.
JC...
Old 11-03-2006, 09:17 AM   #7 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
umm I wonder where the measurement is being taken from?
I mean a 245/75/16 has a 245mm width or 9.65".
Same as a tyre like a 31.10.50R15 has a 10.5" width which would be equal to a 265/xxR15 in metric width (is actually 266.7mm).
The 8.5" you have isn't the rim width requirement is it? Such as a 8.5j rim (16x8.5).
The Best 4X4XFar
Old 11-03-2006, 09:50 AM   #8 (permalink)
01001010's Avatar
Gallery: 15
Hmmm...i guess I should call them up and see from where to where it is that they are measuring. If anything I'll show up air down and have them measure the contact patch..lol
JC...
Old 11-03-2006, 10:11 AM   #9 (permalink)
on, off, on, off, on...
Capt. Ron's Avatar
Yup, 225 will put you there, (8-55/64") No wider.
Acutally a 230 is much closer (9-1/16") If you wanna show 'em that.
03 Disco w/CDL
95 Disco
98 Disco: my first (gone)
Capt. Ron is offline   Reply With Quote
Old 11-03-2006, 11:10 AM   #10 (permalink)
01001010's Avatar
Gallery: 15
aha...got the exact thing i needed....Tread Face width...my tire is 9.6 wide over all...but my tread is like 8.5
So then a 265 should be more than a enough, correct?
JC...
Old 11-06-2006, 08:38 AM   #11 (permalink)
Capt. Ron's Avatar
If they require AT LEAST a 9" tread then yes, you'll be fine with that. Anything over 230 will be within the regs.
03 Disco w/CDL
95 Disco
