ภาษาไทย
Before you go and post something, see if this answers your question. Going with a larger tire means you'll go slower and use more gas. Increasing tire size also changes the gear ratio and adds stress to the drivetrain.
Discovery I 94-99 <29" 205/80/16: Stock size in other countries. same height as 235/70-16. 235/70/16: Stock tire size. 255/65/16: same height as stock but wider 225/75/16: same height as stock but narrower 245/70/16: a little taller and wider than the stock size 30"-31" 255/70/16: slightly taller and wider than stock, but still fits with no lift. 245/75/16: fits on stock height but popular size for 2" lifts. some trimming on the rear wheel well and adjustment on the steering stops. 215/85/16: same height as 245/75/16 but narrower. 265/70/16: about as tall as 245/75/16 but wider. 32" 265/75/16: Same as stock Defender tires. Will require some more trimming. lift highly recommended. 235/85/16: same height as 265/75/16 but narrower. 33" 255/85/16: about 33". a lot more trimming required and you should consider upgrading to hd axles. 285/75/16: also about 33" but wider. a lot more trimming required and you should consider upgrading to hd axles. offset whdeels recommended. Discovery Series II 99-04 <29" 255/65/16: Stock tire size. 255/55/18: optional stock size. 30"-31" 255/55/19: stock size for range rover III. works fine for DII 255/70/16: a little taller than stock. 245/75/16: a little taller than stock. tire manufacturers recommended these be fitted with 7" wheels, but 8" works fine. 32" 275/70/16: possible to fit without lift. minor rubbing. 265/75/16: possible to fit without lift. minor rubbing. 285/60/18: 32" tire for the 18" rim. costs much more than 16". 33" 285/75/16: even taller than 265/75-16, requires around 3" of lift. Very wide and requires trimming. consider upgrading to hd axles & getting lower gears. 255/85/16: a bit taller than 285/75-15 but narrower. consider upgrading to hd axles & getting lower gears. Defender 32" 265/75/16: stock size tire 235/85/16: same size as stock but narrower 33" 255/85/16: 285/75/16: 33x12.5: >34" 305/75/16: 35x12.5: Range Rover 4.0/4.6 96-02 <29" Stock tire diameter. 255/65/16 255/55/18 30"-31"* Works well with EAS but rubs a little on access mode. Fills tire wells nicely. 255/55/19 (RRIII wheels & tires) 255/70/16 245/75/16 265/70/16 32"* Fine on high mode, but will rub on the lower settings. May not be able to turn on access height. Highly recommended that you convert the EAS to lifted coil springs. 275/70/16 265/75/16 285/60/18 *any size bigger than stock will not fit in the spare tire holder in the floor. Here's a great tire size calculator and comparison. Calculator & Comparison Rovertracks and Great Basin Rovers both sell HD axles for those wanting to or are running bigger tires. Rovertracks Great Basin Rovers Last edited by llesra : 07-09-2007 at 07:46 PM. |
Arsell, that is about the best write-up I've seen on for a tire conversion chart as I"ve seen. Thanks for taking the time to do this.......Time to start sweet talking the wife
There's no right way to do the wrong thing..... 96 Discovery I 2" lift/OME med. duty springs MoFab Sliders Flowmaster Exhaust w/ 3" piping Goodyear MTR's 4'x4' roof rack by Coleman Additinal 12v power points and the all important C.B.radio |
#4 (permalink) | |
The Best 4X4XFar
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#5 (permalink) | |
Ryan :: Off-Road/Accessories Moderator :: Gallery 2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone) |
:)----(.Y.)
![]() Join Date: Oct 2005
Great post arsell, I wish we could make it a sticky. Do mods have that power now?
I've already got tires, but for the sake of someone I'm trying to help; What would be the best tire size for use in a stock disco II with regards to off-roading? I'm thinking 255/70/16s. They will be a bit taller and have the same width as the stock tires. I personally think the DIIs would 'like' the slightly wider 255s over the 245s.
Josh Shapiro DII |
#7 (permalink) | |
The Best 4X4XFar
Thus what is right for one person can be completely wrong for another.
:)----(.Y.)
hehe, I know, but if we create a simple scenario where the person will be doing light off-roading with a stock vehicle, but is looking for slightly larger and more agressive tires.
It's hard to say there is a 'best' tire size, but its not to difficult to say there is a 'best fit' (ie. average best) that most people would be happy with. There are reasons why the majority of off-roading DII owners don't have 245/70-16s....I'm trying to find out what is the commonly used size for this purpose w/ a stock lift and perhaps the reasons behind using that size of tire.
Josh Shapiro DII |
#10 (permalink) |
I found this on another land rover site, thought it might be useful:
"Bigger Tires have something to do with my speed, mileage and oil?" What you talkin' 'bout Willis? got to thinking… which is scary in and of itself… but I thought I would share my thoughts anyway. Speed. Or lack there of. Fuel efficiency. Or lack there of. Scheduled maintenance. Hmm… Like many folks reading this, I’ve fitted larger tires on my truck. Like a lot of you, I run 265/75 16s. I’m sure you’ve noticed your speedometer is off. If you haven’t, it is. Running three different GPSs over several semi-controlled experiments, I found my speedometer/odometer to be about 11% off. If I am going an indicated 65 mph on the speedo, in reality I am going just over 72 mph. No biggie, I just run around an indicated 60 mph which is equivalent to 67mph and forget about it. If my odometer says I have gone 100 miles, I have really gone 111 miles. So what’s the big deal? Let’s take a look at the components of the term “mph”. Miles Per Hour. If your mph is off 11% like mine, guess what’s really off… your miles. An hour is an hour is an hour. It’s constant. It doesn’t change, but your miles do. If you are going 65 mph that means in 1 hour you will cover 65 miles. If your speedometer is off 11% like mine is, you really have covered over 72 miles in the same hour. Now, think of the total time you have driven your truck. If you've been behind the wheel 1,000 hours... that is a constant. For example: if you have 67,500 miles on your odometer and you have had larger tires on the truck over these 67,500 miles, that means in reality you have 11% more miles than the indicated 67,500; your truck really has nearly 75,000 miles on it! And, how frequently do you change your oil? If you do it according to Land Rover, you change it every 7,500 miles. If you do it according to common sense, you more than likely change it every 3,750 miles (half of the 7,500). And some of you change it every 3,000 miles. So let’s talk about a few things… I already talked about speed. If your speedo is off by 11% like mine, here’s a chart of how fast you are really going… Indicated on the Speedo What you're really doing 25 mph - 28 mph 30 mph - 33 mph 35 mph - 39 mph 40 mph - 44 mph 45 mph - 50 mph 50 mph - 56 mph 55 mph - 61 mph 60 mph - 67 mph 65 mph - 72 mph 70 mph - 78 mph 75 mph - 83 mph 80 mph - 89 mph Back to oil. How frequently do you change yours? If you said 7,500 miles per Land Rover’s recommendation, then taking into account the 11%, you’re really not changing the oil until it has been in your engine over 8,300 miles! If you go with the 3,750-mile interval, in actuality you are changing it at just over 4,150 miles. And you 3,000-mile folks are changing it after it has been in your engine for 3,333 miles. And beyond oil… think of all of the other maintenance items that are based on mileage… Now, let’s say you wanted to buy a used rig. Let’s say you found one with 82,000 miles on it. That’s not too bad. Good price? You decide to buy it. If this truck has had larger tires on it it’s entire life, and if the speedo/odometer was off 11%, the 82,000 miles indicated on the odometer is really over 91,000 actual miles on the truck! Would you pay the same thing for a truck with 82,000 miles verses a truck with 91,000? So, what are you saying? Watch your speed. If you have larger tires, check your odometer against a GPS. Find out if it is off. If it is, calculate the difference by using the following method and calculation: Reset your odometer and GPS to zero. Drive 10 miles (preferably in a straight line… interstate… on a clear day… so GPS isn’t affected). How many miles does your GPS say you went? Mine would say 11.1. The difference I found is about 11% with 265/75 16 tires. Your truck may be different. It may be 9% off… it may be 13% off… it may not be off at all (but I bet it is though if you have larger tires). Oil changes? If you truly want to change your oil at 3,750-mile intervals and your speedo/odometer is off by 11%, then you have to change it at 3,380-mile intervals using the odometer. And for those of you who let it slide to a 7,500-mile interval, you would change yours at a 6,760-mile interval if you used your odometer. A silver lining? On a positive note, say you fill up your tank with 25 gallons of fuel at an indicated 300 miles on the trip meter, doing a quick calculation, that's 12 mpg. But, that's also off by 11%... so in reality you're really getting 13.3 mpg! WOO HOO!!! Another positive note is that you can sell your rig for more than it should be worth to someone who hasn't read this article... I guess you could always get your speedo/odometer corrected and avoid all this... As always, if you have any questions, feel free to ask! -- Bill Mallin |
#12 (permalink) | |
NextStepDesigns Blog Archive LR3 wheel & tire specifications and options
#14 (permalink) |
I need some advice!
Ive got a 1994 300tdi Disco + have recently bought some new wheels and tyres - 32". 11.50 x 15. Ive got some box sections of steel which i'm going to put under the springs to lift it +2" (any advice on compressing the springs?). I also got new shocks, the rear shocks are +2" to account for the extra distance which they need to reach, but the ones for the front are standard in length because the 2" box section of steel at the front will go underneath both the spring and the shock. I know that some cutting of the bodywork is necessary and have heard that tin snips are the best tool to use, but where to cut and how much to cut? Is there anything else which i'll need to do to retain full articulation when off road? Any further advice? |
#15 (permalink) |
There is another size for us stock D2 owners.
255/60/18 I do not know of too many tires in this size except for the General Grabber AT2 The 60 series tire has 3/32' more tread than the 55series tire... (longer tread, life more initial traction?) The difference between the sizes is: 255/55R18 Load Index 109 = 2271lbs (1030kg) per tire Speed Rating “H” = 130mph (210kph) 109H XL Not Rated For Severe Snow Treadwear: 480 Traction: A Temperature: B480 A B MaxLoad 2271 lbs. Max.Inflation 51 psi TreadDepth 14/32" TireWeight 39 lbs. RimWidthRange 7-9" Meas.RimWidth 8" Sect.Width 10.4" Diameter 29" RPM 695 255/60R18 Load Index 112 = 2484lbs (1129kg) per tire Speed Rating “H” = 130mph (210kph) 112H XL Not Rated For Severe Snow Treadwear: 640 Traction: A Temperature: B640 A B MaxLoad 2469 lbs. Max.Inflation 51 psi TreadDepth 17/32" TireWeight 39 lbs. RimWidthRange 7-9" Meas.RimWidth 7.5" Sect.Width 10.2" Diameter 30" RPM 695
03 Land rover disco 2 - Exhaust mod - current 02 BMW 530I - Sports and premium packages - current 88 Dodge ram 50 2wd - flatbed - current 87 Porsche 944 turbo - modified - traded for disco 06 Subaru WRX - stock - traded for 530I |
