Polish and proud of it.
Yeah I'm looking to get some junk yard 15" rims and mode then at work ( mashine shop ) to fit the bolt patern on my Disco II .
Now What is the offset on the stock rims ? Casue this rims will be -6 mm I found that stock MIGHT be +40mm offset . Thus making the center of the rim move out by 46mm ( not full 2" ) . But since the rim is 7" it will make it only stick out 33mm from the original rims . But That's if the stock rim is +40mm. Can I get some help here ? OH and will the aftermarket 15" will clear the rottor ? Thanks Art
![]() I'm a Proud owner of a vehicle that has a turning Radius of 747 ![]() Check out our Frappr! Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew |
#3 (permalink) | |
Mud and stuff? where the rottor is ? and rim to stretch ? They sell that rim in that bolt patern but it's -19 offset ( so it's more out ) . BTW that rim's face is practycly flat . But $30 per rim I don't mind .
Otherwise known as STEVE
actually, there have been Discos running 15" wheels for years. I think 15" was standard on the 3 door commercial Disco.
Get proper wheels though- bodging a junkyard wheel by redrilling it is hack.
Well I found out what the off-set is on those rims .
It's 57mm and the rim is 8" wide. So those -6mm 7" wide will posibly stick out more or less 2" . Thats to much . I will tare up the fenders on the stock lift .
Safari Gard does have the steels under accessories @ $75 Each
Wheel info: http://www.landroverclub.net/Club/HTML/Wheels.htm |
