Old 08-28-2006, 09:36 AM   #1 (permalink)
timkel74@msn.com's Avatar
Default D1 with 247/75 16 pics wanted...
I have a 97 D1 (no mods or lift) and would like to see some pics of other D1's with this tire size on it without mods or lift. Also, how does everyone feel about the Dunlop Radial Rover AT's? They seem like a good deal at $114.00 per at tirerack.com. Plus, $50.00 back when you buy 4 tires. (102.00 seems like a steal) .
timkel74@msn.com is offline   Reply With Quote
Old 08-28-2006, 09:45 AM   #2 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
245/75/16 goodyear mt/r with no lift. fits nicely with only slight rubbing on the rear.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 08-28-2006, 09:47 AM   #3 (permalink)
Steven Ratajczyk
stevenr's Avatar
Here's my truck with 245/75/16 BFG MTs and no lift. I did need to trim rear quarters a bit for off road. Can't really help ya with the Dunlops either.
Steven Ratajczyk
'99 Disco 1 with stripes
stevenr is offline   Reply With Quote
Old 08-28-2006, 09:49 AM   #4 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Get yourself a fifth one for the spare also. Depending on what/how much wheeling you do you might want to think about getting the Dunlop mud terrains. Great looking and in the snow the mud terrains work great too. I have the 245's on my 97 with no lift and I love them. You will have to trim the rear fender so the tires won't rub though. Sorry all I have are action pics right now.
Old 08-28-2006, 10:05 AM   #5 (permalink)
So, I'm the odd man out if I dont get the M/T rated tire??? I dont do much off road but, hope to soon. I do a lot of highway, will the M/T's be very loud? Will they wear quicker? Any suggestions? Help!!!
Old 08-28-2006, 10:05 AM   #6 (permalink)
Badger,
Saw your trucks pictures, I assume this id where the ABS extensions are going, what sort of a lift are you going to go to?
Old 08-28-2006, 10:51 AM   #7 (permalink)
01001010's Avatar
Gallery: 15
http://www.96d1.com/Pictures/Picture...i/DSCF0071.JPG
You'll definately need to trim your rear fenders. I'm still on stock suspension.
JC...
Old 08-28-2006, 11:00 AM   #8 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Originally Posted by Disco Mike
Badger,
No actually they are going on my wifes truck. She has a two inch OME lift and I have installed quick disconnects on the front and will be taking off the rear swaybar. While the truck was on the lift at the dealer and they were bleeding the brake system after installing all new lines and extended SS soft lines, I noticed the rear ABS lines were about a half an inch from being tight enough to be a good guitar string. So I said to myself... "self, you had better get some extended abs lines for the wifes truck, or I will be ripping those lines out after I take off the sway bar".
My D1 has been without front or rear sways for better than a year with no problems. It is soooo much better off road without em. Haven't had any issues with brake lines or anything and it flexes pretty good. It's always great(being sarcastic) when you hear the springs going boing, boing. That's it....time for a lift!
Old 08-28-2006, 06:00 PM   #9 (permalink)
Thank you for your help and advise. I purchased Dunlop Rover A/T's today in the 245/70 16's. When I grow up (someday) I will put a 2 inch lift, remove the sway bars, extend the ABS lines, and swap out these tires for BFG's 285/75 16's.
Until then, these give a little better look to the D1 and I have slightly better ride quality. I will post pics when I get them. (if anyone is interested.)
Everyone was helpful. Thanks again.
Old 08-28-2006, 06:27 PM   #10 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Hell yeah, post up some pics! You will love the tires and it will look really good too! Congrats on your purchase.
Old 08-28-2006, 06:43 PM   #11 (permalink)
There already on and the do look great. Glad I went with them. Thanks again...
Old 08-28-2006, 11:39 PM   #12 (permalink)
the big yellow one is the sun!
VArova87's Avatar
which is a bigger tire, 245/70/16 or 245/75/16? is one wider?
97 D1
3" OME
32x11.50 BFG ATs
GCR steels
headers, exhaust, etc...
VArova87 is offline   Reply With Quote
Old 08-29-2006, 04:39 AM   #13 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
The 245/75 is a bit taller, 5% actually. Both are the same 245mm wide. The 70 or 75 is just a percent from the width to tell you the height, ie: the 70 is 70% of the 245mm width, a 235/85 would be a taller tire being 85% of the 235 width. A 245/75 is about the biggest tire you can fit under a stock suspended D1.
Old 08-29-2006, 07:02 AM   #14 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
I've got a set of 31.10.50R15's Think they are equiverlent to a 265/65. They fitted fine on my Discovery. I did have to take the front bumper corners off as it rubed on them, but it seemed fine at the back, although I do have a 3 door.
Not an issue know as I have 'slightly' altered the wheel arches
The Best 4X4XFar
