Old 08-12-2008, 11:57 PM   #1 (permalink)
Default heavy duty springs ome what tires?
well i have the old man emu heavy duty springs and shocks on my 01 disco. my current tire size is a 255 70 r16. i want to put on 31s... i think. but i was just wanting some feed back or maybe pics if somebody else has done this.
Jmorris6689
jmorris6689 is offline   Reply With Quote
Old 08-13-2008, 09:40 AM   #2 (permalink)
98xc800's Avatar
Here is a link to my thread about my 31x10.50/15 install on a DII
99 DII with 31x10.50/15 on BMW 15" steelies-No lift
99 D2
31x10.50/15 Pro Comp XTerrains on BMW steel 15x6.5 wheels.
98xc800 is offline   Reply With Quote
Old 08-13-2008, 06:24 PM   #3 (permalink)
got mud?
Jupiter Rover's Avatar
32's should fit. I ran 285/60 r18 (31.5's) with OME lift
DII
-- Pete
285/75 r16 Destination M/Ts
Old 08-13-2008, 10:26 PM   #4 (permalink)
32 sounds good but i just realized my tire is a 255 70 r16 which is about a 31 im thinking now about some 33s
Jmorris6689
Old 08-14-2008, 07:12 AM   #5 (permalink)
got mud?
33's will be a very tight fit.. front bumper will definitely need to be trimmed. Depending on the back spacing of the wheels, You will rub when you turn. Turning will be harder..
Some guys on Dweb have said they have put on 33's with the OME HD lift with trimming ect.
What kind of wheeling are you planning?
There is a ton of information on discoweb.org -- if you search.
DII
-- Pete
Old 08-14-2008, 07:49 AM   #6 (permalink)
I run 265/75/16's, 31.9" with no issues.
Just remember the taller you go the more gas you burn and the quicker your spider gears, if still stock, will fail.
Old 08-15-2008, 10:24 PM   #7 (permalink)
sounds good mike, ive already been through one set of gears. what gears could i switch to that would be stronger? 4:10s?
Jmorris6689
Old 08-15-2008, 11:31 PM   #8 (permalink)
2002 Discovery II SE
I rubbed a little on the front bumper until I straightend it out. It was a little mangled from previous off-road endevours.
But other wise, no rubbing at full lock or anything.
2002 Discovery Series II SE. 2" OME Heavy Duty. 265/65R18 BF Goodrich All-Terrain T/A's.
I told my wife if the Land Rover goes, so do I. That shut her up.
Alak is offline   Reply With Quote
Old 08-16-2008, 01:42 PM   #9 (permalink)
fivespddisco's Avatar
Gallery: 10
just to clarify, Putting bigger springs on the truck does not increase the ware and tear on the drive train. Putting lager tires on the truck does.
Check out WWW.Lucky8LLc.com 716-898-8153 Justin
fivespddisco is offline   Reply With Quote
Old 08-16-2008, 02:00 PM   #10 (permalink)
Gallery: 10
The stock Ring and Pinion are very strong, the carrier or spider gears are the weakest part of our 3rds.
With the proposed 33in tires your in a funny spot. If you install 4/11 gears they will be a tad to short on the hiway,and this will will not address the weak carrier. We can argue about which is stronger stock Ring and Pinion or after market Ring and Pinion but you still have the Spider gears just waiting to be shock loaded so they can transform into tiny bits of gear smashing metal.
With the 33s in mind you can upgrade the carriers to an ARB or a True Track style. This not only will give you better traction when you need it, But strengthen the diff where it needs it most.
I hope this helps
Old 08-16-2008, 04:33 PM   #11 (permalink)
where do i get true track carriers? it sounds like an investment that is well worth my money
Jmorris6689
Old 08-18-2008, 06:29 AM   #12 (permalink)
Gallery: 10
Try Keith at Rover Trax 303-506-9429
Old 09-09-2008, 02:24 PM   #13 (permalink)
emmett distresser
beast o bodmin's Avatar
I run 265 75 16 on ome lift.seems fine.
V8 Is the only way.
beast o bodmin is offline   Reply With Quote
Bearmach Heavy Duty Blue Springs DII, RRC, D1 TNRRClassic Land Rover Parts and Accessories 10 09-02-2008 09:41 AM
18X9 Wheels on my 2inch lift 95 classic tebelleh1 Range Rover Classic 9 04-23-2008 11:06 AM
OME - Medium or Heavy Duty? Danger Accessories 10 04-05-2008 10:20 AM
Trade OME front med for heavy duty mud rutts Land Rover Parts and Accessories 0 04-26-2007 10:56 PM
Wanting to buy medium heavy duty springs.. xtremistSD Discovery Series I 3 08-16-2005 08:00 AM
