Old 10-23-2006, 11:44 PM   #31 (permalink)
Choqiees's Avatar
Originally Posted by smileyq
So much for reselling my factory bumper when I get my aftermarket one. I'm not a big fan of doing any trimming honestly but if this will make those tires work for the time being I'll do it. Anybody have and pictures?
in this picture, you can see where I trimmed the lower corner of my front bumper...and you can also notice the front bumper is kinda bent so if your front bumper is straight...you might not need to trim as much as I did to mine.
it's 265/75 with 2" OME
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 10-24-2006, 07:40 AM   #32 (permalink)
smileyq's Avatar
Thats great thanks. Obviously I've never trimmed a vehicle before what tools would I need to make this look professional and to keep it smooth and straight.
"Good saddles ain't cheap, and cheap saddles ain't good."
smileyq is offline   Reply With Quote
Old 10-24-2006, 10:25 AM   #33 (permalink)
New Land Rover Owner
I am going to put the 245/75R16 Wrangler MTR's on my truck hopefully in just a couple of weeks. Not sure yet on a lift, but I deal with that if I have to. Can't wait to see how different the truck looks with 16" wheels and tires, vs the 18" wheels and tires.
2002DiscoII is offline   Reply With Quote
Old 10-24-2006, 10:33 AM   #34 (permalink)
Choqiees's Avatar
I have no idea on what tools you need to use...the shop had it done for me
I remember they used grinder, but I thing that was for the metal that's sticking out when you trim the lower corner.
Old 10-26-2006, 11:06 PM   #35 (permalink)
Ataraxia's Avatar
I recently installed 265/75/16's BFG mt's on my truck and the only rubbing I have had was on the front mud flap that is cast into the OEM side steps (when I have a some time, I'm instantly going to rip those things off).. I trimmed about 5mm off a sharp edge on the inside and that did the trick. the rears are good to go without any trimming.
I'm still going to do a 2" lift...
Dan
Ataraxia is offline   Reply With Quote
Old 10-26-2006, 11:21 PM   #36 (permalink)
smileyq's Avatar
I already took my front mud flaps off when I installed my sliders. Do you have any pictures of what you had/need to trim. I'll be getting my tires in soon.
Old 10-26-2006, 11:22 PM   #37 (permalink)
Ataraxia's Avatar
I would at least go 265/75/16, especially if your planning to lift it. I expected mine to be a bit wider than the 255/55/18 they replaced, but the overall tire looks thinner. I dunno, the 30x10.5x15 I had on my Blazer looked beefy. I regret not going with the 285/75/16. A small tire looks wrong on lifted a Disco.
Ya I know, looks don't count.
Dan
Old 10-26-2006, 11:33 PM   #38 (permalink)
Ataraxia's Avatar
Sorry, I don't have pictures, but since you removed your flaps, you should be already good to go. Totally streetable. Just don't go full blast hard-core off roading until you do a lift.
Dan
Old 10-27-2006, 06:41 AM   #39 (permalink)
smileyq's Avatar
Good deal. Thanks for the new info. I'll post pictures when I get them on.
Old 10-27-2006, 09:45 PM   #40 (permalink)
smileyq's Avatar
Default Too late to turn back..
Well I did it ordered my tires today. Goodyear Wrangler MT/R in none other than the 265/75/16. I will let you know if I have any problems. Thank you for all the help I have received. You guys rock.
Old 11-02-2006, 09:10 PM   #41 (permalink)
smileyq's Avatar
Well finally got my tires.... Now if I can only get all of my wheels...
