Old 03-15-2007, 04:37 PM   #31 (permalink)
Buddy Lee's Avatar
Another late poster here.
Here is mine with an RTE 2" HD springs and 235/85-16. The thing to keep in mind about RTE springs I've seen a couple of people mention that they give more than 2" which they do if you have a stock truck. The RTE is designed as an off road spring. This means they are heavier and designed to give the appropriate lift with all the correct gear attached. I got 2 3/4" lift with my HD spring over stock. Once I added the RTE Front Bumper 105lbs, and winch 100lbs, roof rack ~ 100lbs and about 200lbs of tools and equipment it sat exactly 2" over stock.
'97 Disco
Buddy Lee is offline   Reply With Quote
Old 03-16-2007, 12:10 PM   #32 (permalink)
AAXD's Avatar
Gallery: 1
Since there's a few folks here with 2 inch lifts running 265/75's, what kind of body trimming is involved? I'm considering finally modding my Discovery. After driving it for 2 years with stock springs and smaller than stock tires, I'm feeling a bit inadequate.
Colin's Toys:
1972 Series III 88"
1997 Discovery XD
1983 Stage 1 109"
2002 Trek 4500
2005 Necky Looksha Sport
2007 Rans Rocket
2007 Honda Ruckus
Old 03-16-2007, 05:14 PM   #33 (permalink)
If you use a stong OME 2" lift, you will not need to trim anything. May have to adjust a steering stop, but that is no big deal.
Old 03-17-2007, 12:00 AM   #34 (permalink)
Buddy Lee's Avatar
Are you talking DI or DII because every DI I've ever known about if it's going to be off roaded needs to have a little bit trimmed off the rear quarter for 265/75 or 235/85. The DII on the other hand tend to be ok with those and no problems.
'97 Disco
Old 03-17-2007, 12:00 PM   #35 (permalink)
JWilliams's Avatar
I bought the HD OME 2" springs. No trimming at all... I did have to adjust the steering stops, not much though.
JWilliams is offline   Reply With Quote
Old 03-17-2007, 12:28 PM   #36 (permalink)
Buddy Lee's Avatar
Right because you have a DII! As I mentioned in my post DII's are different then DI's.
'97 Disco
Old 03-18-2007, 12:28 PM   #37 (permalink)
Majesticdisco1
disco12's Avatar
Buddy good lookin Truck
1996 D1
J "Crawler"
camo,33x10.50's
Old 03-18-2007, 09:06 PM   #38 (permalink)
Mean and Green
Originally Posted by FrankyRizzo
I would be leary doing this in more than 2 inch lift. This was from this weeekend.
Ahh, don't underestimate your Disco... This is from my '03 w/ 3" lift and 2" spacers:
werldcup is offline   Reply With Quote
Old 03-31-2007, 11:27 AM   #39 (permalink)
Giver of Last Rights to Fallen Rovers
Default 265/75
Not to highjack but those of you running 265/75's with a 2" lift do you have rubbing problems. My 2" OME lift gets here next week and i am looking at tries.
Marty
270 576 7922
Drillbit is offline   Reply With Quote
Old 03-31-2007, 01:20 PM   #40 (permalink)
Majesticdisco1
disco12's Avatar
Marty
I have rubbing at full turn other wise no biggy. I would say get tires in a 235/85/16 size. It's the same size as the 265 but is narrower so You don't have to worry about rubbage.
1996 D1
J "Crawler"
camo,33x10.50's
