Old 10-30-2005, 04:58 PM   #1 (permalink)
beavis4g63t's Avatar
Default LT255/85R16 trxus m/t
what do you guys think of this tire with a 2 inch lift?
TrXus Mud Terrain
The NEW TrXus Mud Terrain is INTERCO'S answer to the need of those who want a smooth, super quiet ride with tough, thick sidewalls with a chip and cut resistant compound. This tire has more siping than any other mud terrain on the market; which has proven to be almost magical in icy snowy conditions. These same traction features make this tire a serious rock climber.
Each TrXus Mud Terrain tire has its individual specifications and is heavier than the original equipment tires of comparable size. Many brands of tires are made from generic specifications which means there are many "brand names" coming out of a particular factory but all the tires have a common specification basic body or casing. The only difference is the mold the tire is cured in. The tires will have different tread designs but the body of the tire is common to many others of the same size but under various names.
beavis4g63t is offline   Reply With Quote
Old 10-30-2005, 04:59 PM   #2 (permalink)
The guy with the Banhammer
keptin's Avatar
depends, what rover do you have? A DI?
Josh Shapiro
DII
Old 10-30-2005, 06:14 PM   #3 (permalink)
yes 98 d1 soon to be far from stock.
Old 10-30-2005, 08:20 PM   #4 (permalink)
keptin's Avatar
I personally think it wouldnt be worth the problems assosiated with fitting a tire that large. Sure you going to gain ground clearance, but at the cost of extreme vehicle butchering to try to fit that size tire so it can tuck up.
Take a look at 235/85-16's, they seem to be a very common tire with OME 2" lifts and dont require the intense trimming/cutting that you will need with a 255/85-16.
There is also 265/75-16's, but you will have to increase the bump-stop length otherwise it will be bad when it tries to tuck up far. Thats why I would prefer the 235's.
Wait a bit longer to see if anyone else with DI's post with personal experience. I have a DII with 265/75-16's that fit perfectly and are awesome.
Josh Shapiro
DII
Old 10-30-2005, 09:04 PM   #5 (permalink)
Art Vigil's Avatar
Default Wouldn’t be prudent at this juncture
I think you'll need more than a 2" lift to fit that tire on a D1. In the attached photos, the D90 has the 255/85/R16's, the RRC has 235/85/R16's. To run the 235's you'll either need to do some trimming or a 2" body lift. Plus, you'll need to replace your drivshaft or you'll end up with some serious vibrations.
Good luck,
Art Vigil
Denver City, CO USA
'95 RRC SWB TWR Edition
'72 Series III 88" (Rita)
'97 D90SW #2426 (sold 3/05)
'95 D90ST #2620 (sold 10/01)
Art Vigil is offline   Reply With Quote
Old 10-30-2005, 09:06 PM   #6 (permalink)
LT255/85R16
width
7.40
tall
32.7
recommended rim
16x7
LT265/75R16
width
7.70
tall
31.9
recommended wheel
16x7.5
do you guys think the narrower but taller size would be doable?
Old 10-30-2005, 09:14 PM   #7 (permalink)
Art Vigil's Avatar
I'm not sure if the tire you're looking at is different, but the BFG MT is 33.3" tall, 10" wide on a 7" wheel in the 255/85 size. In the 265/75 size it's 31.9" X 10.5.
~Art Vigil
<edit>
Here's the BFG Website, if anyone wants more info:
BF Goodrich Tires
Denver City, CO USA
Old 10-30-2005, 09:41 PM   #8 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
i've got that tire in 265/75/16 with about 3" of lift on my DI. i didnt have to cut much but if you fit that tire with 2", a lot of trimming will be needed and you will have to adjust the steering stops.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 10-30-2005, 09:50 PM   #9 (permalink)
Elephantitis penisitis
I run 265/75/16 MT's on The Black Widow with a 2" lift. Had to do minimal trimming and did not adjust the steering stops.
lt255-85r16-trxus-m-t-capture2.jpg  lt255-85r16-trxus-m-t-capture7.jpg  lt255-85r16-trxus-m-t-capture13.jpg  lt255-85r16-trxus-m-t-capture12.jpg
Old 10-30-2005, 09:56 PM   #10 (permalink)
~Art Vigil
<edit>
BF Goodrich Tires
i'm looking at a completely different tire.
Old 10-31-2005, 12:21 AM   #11 (permalink)
rmuller's Avatar
trxus 255/85 is 32.7x10.1 .. the 265/75 is 31.9x10.5 ... you wont fit a 255/85 on a DI without some trimming and steering stops adjustments...
Old 10-31-2005, 02:56 AM   #12 (permalink)
Discrover's Avatar
Yep...I agree with Ryan...with 2" lift you might get away with 265-75-r16 but that is going to be the tallest you can go...
You can fit that tire on a D1, but like everyone said you are going to have to trim...or you are going to have to either add bigger 5" springs or spacers which most people who really seriouly offroad hate the spacers...so if this is a trail rig go with the larger springs...but then you are again talking about different shock set up...back and front drive shaft conversions and $$$$
With what you have now you can pretty much buy the 265-75-r16's and slap them on and go on your way.
If you want the extra inch or so of hight from a 255 well get out your check book because I have spent over a grand trying to get to a 33" tire and I am still not there yet...I am still running a 265-75-R16...until I get 5" springs and a few more things...
On my own truck;
front and back drive shaft conversion done...trailing arms...longer brake lines...gees the list goes on and on...and seems like I will never get to a 33" tire...Oh and lets not forget the terrible wheel hop that I get ever since this new set up on the front end of my truck that sometimes just comes out of no where and feels like extreme turbulence on an airplane.
OH, Gees how could I forget the Bilstein 7100 shocks that were like $700 dollars for 4 of them...so you can run the 5" springs....Holy crap I have spent closer to $2k...after remembering the shocks..
Well...have fun...or remember you could just really trim allot and install fender flares flares....which I may do as well before I am all done.
Discrover
myrover.net
RAVphotography | My Car Domain Page
Discrover is offline   Reply With Quote
Old 10-31-2005, 07:57 AM   #13 (permalink)
rmuller's Avatar
I dont think a lift alone will help, it will most likely hit on the outside bottoms of the fender when articulating.
Old 10-31-2005, 09:49 AM   #14 (permalink)
appstatedisco's Avatar
I have a 95 disco I with 265 truxXus m/t's. I have a ome 2" lift, but it's the heavy duty one, so it might be more like 2.5". I have only rubbed in extreme situations when the wheels are turned all the way.
AHO Rugby, a drinking club with a rugby problem.
www.ahorugby.net
"My experience through life has convinced me that, while moderation and temperance in all things are commendable and beneficial, abstinence from spirituous liquors is the best safeguard of morals and health."
- Robert E. Lee
appstatedisco is offline   Reply With Quote
Old 11-09-2005, 01:47 PM   #15 (permalink)
I have the tires you are looking at - 255/85 trxus. I do not know if they will work in your case, most likely will rub under articulation. In order to run mine safely I did a lot of stuff:
3" RTE springs
longer/bent front radius arms
castor corrected swivels
longer rear trailing arms
longer front shocks
brackets to lower rear shocks 2"
extended brake lines
2" bump stop extensions plus Defender bump stops
2" sway bar mount extensions
double cardan front driveshaft off a DII
u-joint rear driveshaft off an RRC
about 2" trimmed off bottom rear of rear wheel wells
Given all of that the tires work great. But they are still close under articulation thus I think you will have problems with just 2" springs and nothing else.
RichardS is offline   Reply With Quote
