» Sponsors
» Sponsors
Old 03-30-2006, 10:41 PM   #1 (permalink)
spiderfreak80's Avatar
Gallery: 5
Default Please clarify tire info !! :))
This info is off the basic tire info posting for the 99-04 Disco II-
32"
275/70/16: possible to fit without lift. minor rubbing.
265/75/16: possible to fit without lift. minor rubbing.
285/60/18: 32" tire for the 18" rim. costs much more than 16".
Question is....on the 285/60/18 is it the same as the other two
that it will work without lift, with minor rubbing?
Thank you to anyone that can verify this info for me !
spiderfreak80 is offline   Reply With Quote
Old 03-31-2006, 08:35 AM   #2 (permalink)
Super Moderator
What this information is not mentioning is that if you do any driving thru hard curves, dips, much less off the road, you will tear up a lot of siedwalls much less wheel well metal.
I run 265/75/16's with a 3" lift and I can still stuff a wheel and get a little rub when playing in the rocks.
What is it you are wanting to do with your truck?
Old 03-31-2006, 04:07 PM   #3 (permalink)
RageRover's Avatar
Well since te tire 285/60/18 is getting wider than the others, yes it might rub against something while turning, although I do not know if they will rub w/o a lift.
I got on my RRC, which might be a slightly bigger wheel well than a Disco, I got 255/65/16 and when I turn hard, like to parallel park, and the steering wheel is locked, she will rub ever so slightly, but she has never rub anywhere else, even during a wheelin' trip.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
-Custom full length roof rack
