Hi,
I am in the process of purchasing alloy wheels for my new Discovery3. Specs are 20" x 8.5 Offset +15/+35 (+35 might be for the 22" x 9.5) right? PCD 100 - 139.7 (what does this mean please)? Will these specs be suitable for ROAD ONLY driving? This is the wheel.. What you think? Thanks all!! http://asiawheels.en.alibaba.com/pro...uto_Wheel.html |
22s and 20s will be suitable for one thing, The urban club.
They will suck as road tires. First off every bump will be felt. The vehicle will pull because it will follow the crown in the road. when you damage the rim or get a flat you will be driving on a very small spare. The vehicle itself will lean and the vehicle will be damaged by the small tire. Secondly you will only be able to go a short distance and at a low speed. as mentioned before it will turn on ABS codes and in your case many other nifty lites will magically appear. The vehicle will not go offroad. Besides why would you waste an investment of all that money to go offroad and damage the wheels. Plus they may rub in the down position or normal or offroad height. Landrovers are designed to go offroad. The Land Rover Sport comes with a set of twentys but it has a newly designed steering rack that absorbs the bumps. Secondly, the sport is designed to go offroad and on with those twenty inch tires. It wont be easy but it can do it. Your 22s wont work and cause more problems the dealer will be happy to make you pay for. They may even cancel your warranty for the hell of it after you show up at the dealer with those rims on. your wasting your money. If you want to look good cancel the order and get a sport that is supercharged and has a set of twentys on it. |
Sounds like good advice but I really would like to go 20"..
Again.. what does this mean? Offset +15/+35 PCD 100 - 139.7 If you were to upgrade on alloys for urban driving, what wheel/tyre and size would you choose? Land Rover have an upgrade of 19" for 2,000euro which is expensive. I thought it might better buying through china and this wheel looks great.. thanks again appreciated ![]() |
#5 (permalink) | |
No relation to Felix The Cat
I know giant alloy wheels are some sort of fashion statement, but save yourself the headache and stick with 19s at the largest, and put good street tires on them. You'll save a ton of money down the road, and if you're lucky, you may retain some shread of dignity. Beezel said it quite well, it's not worth it to do 20s or larger.
Felix J. Lockhart 1995 Land Rover Discovery (Series 1) |
i run 22's on my range rover at all times but winter and don't have a problem with them. As for the offset, get the RWD with a higher offset. This is so the wheels can clear the brakes and sit in the wheelwell with a good stance. You need a high offset for all land rovers because of the wieght of the vehicle and the stance that is needed for stability etc. Do not use the rims off road, or even in snow, as salt used for the road eats away at alloy. I change my 22's out for the winter for that reason, and i like to off road. PM me if you need more info.
98 4.6 HSE Customized to the season |
#7 (permalink) | |
Polish and proud of it.
I can give an advice here . Next time if you want to ask a qwestion like that . Ask only what you need to know .
Like ( What is the ofdset on the rims for LR3? ) with that number you can figure out what rims you need . Now Since There is a problem going big like that . Then Just Avoid the problem , and go with a solution that Will save you the head ache . You want to "pimp" your LR3 out . So If you have to get wheels , get them in the same size as the stock ones are , but in the look that you like . No one can't tell you not to spend your money. If you want to buy an Iceburg , and ship it to africa , You can do that. People will tell you it's a waist of money . but if that makes you happy , do it . Same thing here . You want to have a havy crome wheel that will bling , go for it . Some people will tell you that it looks stupid , But if it makes you happy. That's all it counts . But Yeah I personaly Would not get 20" . Most of my friends want me to get 20" . I tell then to GAFTS . I would like the Range Rover 19" . they look nice . But all this talk about rims . What is the bolt patern on Disco II and LR3? Casue I would like to get rims . and i know it's 5-120mm , but is it the same as 5-4.72" or something like 4.__ " ? I'm going the junk yard rout to get my self some winter/off road wheel .
![]() I'm a Proud owner of a vehicle that has a turning Radius of 747 ![]() Check out our Frappr! Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew |
#9 (permalink) |
The guy with the Banhammer
![]() Join Date: Oct 2005
IF you really want to go 20" then go for it
, just keep in mind of the downsides. Since this forum is mostly based off of LR heritage/off-roading we might have a bias look upon putting high dia. wheels on a rover. Also from a logical standpoint, the only thing they do is "look", even for basic street use they actualy preform worse then the stock wheels with good tires.
Josh Shapiro DII |
#10 (permalink) | |
You are killllling me...........Hmmm.... second thought, I wonder if some spinners would help my Classic with wading? Maybe turn them into propellers....... ![]()
Beer is proof that God loves us and wants us to be happy. ~Benjamin Franklin 1989 RR Classic 1969 Series IIA 3 Kids in College...........
#11 (permalink) | |
I refuse to tip toe through Life only to arrive safely at Death ![]() Rocks, Sand, Mud, Water whatever I just want to leave the pavement Its your Life, LIVE it ENJOY it!
#12 (permalink) | |
DallasRover: If you can find a way to make spinners even vaguely useful, you win a cookie ![]()
