Old 09-09-2007, 02:16 AM   #1 (permalink)
MISSING THE HELL OUT OF SEATTLE
Series 3 guy's Avatar
Gallery: 5
Default Series III tyre question
Hi guy's-
There has been some debate here in the UK around Defenders and Series vehicles that are fitted with the standard steel rims that are tube type being fitted with tubeless tyres with tubes to get the desird tyre without swaping out rims.
Some MOT stations are failing trucks here stating that it could result in tyre failure. Does it have anything to do with anything???
I have been thinking I want to get some more aggressive tyres for my truck but I dont want to lose the original wheels. I have a set of 2005 Defender white steels on her and want to keep the original look as I dont like any newer wheels on the market. Any ideas??? Suggestions??? Cheers- Andy
Missing you Dime.You were taken from us too early my Brother.
82' series III 109 safari prepared 2.25 pet.WILL NEVER GET RID OF!!!!!!
91'Range Rover classic 3.9L V8! I LOVE IT!!
98' Land Rover Discovery with a MOD wolf 300 tdi(sold)
97' Defender 90 300 tdi (sold)
97' Range Rover 4.6L V8(sold)
Series 3 guy is offline   Reply With Quote
Old 09-09-2007, 07:05 AM   #2 (permalink)
antichrist's Avatar
Well, I suppose there's no arguing with the MOT.
FWIW I've run tubeless tyres on tube rims with tubes. The problem you can have is heat build up and failure of the tube, because most tubeless tyres in my experience have been radials which flex more, generating more heat. You need to use tubes made specifically for radials, and plenty of tyre talc. Even then, after a few years you sometimes can find the tube stuck to the inside of the tyre and have it tear on removal.
My suggestion would be tubeless Wolf rims if you're ok with the look.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 09-10-2007, 12:12 AM   #3 (permalink)
Admittedly I'm not up on the why not's and what for's to give any definitive advice,,,,, But FWIW I replaced the original riveted rims of a 109sw with new defender tubed steel rims and mounted up 235/85/16 tubeless tyres.
I was not sure about doing such but when I went to tyre shop and asked .... The two well established independent tyre shops I visited did not fear any much problems.
Mounting tubeless on tubed rims may well end up in some disaster,,,, ,,, Though have yet to have any problems.
Dave
dav1551 is offline   Reply With Quote
Old 09-10-2007, 09:50 AM   #4 (permalink)
Gallery: 5
Dave
Thanks for the info! As a nosy person I was wondering what boat you have?Is that a swim step in the frame of the pic?
Old 09-10-2007, 09:53 AM   #5 (permalink)
Gallery: 5
Good idea about the wolf rims!! I have found a set that are white and do look the part.Cheers!!
Old 09-10-2007, 11:04 AM   #6 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Looks like a Series top to me.
Jim Hall
obstacle.” Michael
Old 09-10-2007, 12:23 PM   #7 (permalink)
Gallery: 5
How did I miss that?? I do believe you are right!! Sad I cant tell the difference....maybe I am not the enthusiast I think I am
Old 09-10-2007, 02:41 PM   #8 (permalink)
Seems that Jim's on it ! ... and correctly identified it as a series top... .. Which may well give some folks pause in questioning his sanity ..... "But fret not Jim we're proud of ya"
In truth I did have one of them go fast bass boats, and used it quite regularly.... But after moving to a new home the lake was not near as convenient for those quick 1/2 day trips that I enjoyed with it.... So sold it off and make use of a mates SeaFox.
Dave
Old 09-17-2007, 08:22 AM   #9 (permalink)
Mad as a Box of Frogs
Spyderman's Avatar
Hi guy's-
AFAIAA Defender steels are tubeless rims, it's just the series rims that require tubes, as the rims aren't air tight.
Who Needs Brakes???
1981 Series III 88" Diesel
Spyderman is offline   Reply With Quote
Old 09-17-2007, 10:47 AM   #10 (permalink)
msggunny's Avatar
Gallery: 5
I dont know what the difference is but i know that the stock rims from my 77 had tubes in them orginally, but then i mounted BFG Trac Edges with out tubes and they held air fine.
I had another set put on that were locally made at a LR place in Harare. No problems since 2003.
When i was in Africa they were putting inner tubes in almost all the tires, they were even on my 91 Disco.
Would be nice to know.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
When god gives you lemons, find a new god....
msggunny is offline   Reply With Quote
Old 11-20-2007, 01:14 AM   #11 (permalink)
Gallery: 5
Theres the answer! Cheers. I chased it up and you are right. Now off to concider a set of BFG At's!!
Old 11-22-2007, 08:29 AM   #12 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
on
At least the earlier Series rims were riveted together, and leaked air from the rivets. They also didn't have the bead to keep the tires seated on the rim. That being said, I ran tubeless tires on them for years without tubes and never had problems. I just had to check the air every now and then.
Jim Hall
obstacle.” Michael
