Old 02-13-2006, 02:58 PM   #16 (permalink)
robbie's Avatar
Originally Posted by rmuller
Thats why you buy another truck to put the old tires on, when you up grade the old truck w/ new tires
ahh, touche`
'95 DI
'00 DII
robbie is offline   Reply With Quote
Old 02-13-2006, 05:28 PM   #17 (permalink)
Originally Posted by robbie
DP - it isn't the lift you would have to worry about so much with larger tires, as it is the rest of the drivetrain. especially if those really have the amount of traction they say. you'll be popping cv's and axles like candy with anything larger than a 33". i would say stick with 265/75 until you upgrade those weak links.
Well it depends on how crazy i get... I'm waiting on a Biz deal to close then i may just get really stupid with the truck(read:along the lines of red rhino's big assed disco) so upgrading weak links won't be a problem but just for shits and giggle what would fit under 5"s trimmed?
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
Old 02-13-2006, 06:03 PM   #18 (permalink)
robbie's Avatar
man, that really depends, especially on amount trimmed. i put 34x10.5 on 3" lift with trimmed fenders. you can probably fit 35x12.50 with 5" lift and trimmed out fenders. this will need extended links to keep the rear tires out of the rear doors. but as soon as you lay on the throttle offroad, you will pop diffs, cvs and axles.
'95 DI
'00 DII
Old 02-13-2006, 06:08 PM   #19 (permalink)
Damn 34's you have any pics? BTW You topless Disco has me all bothered and eyeing my angle grinder and sawzall. But i would seriously appreciate any pics. If i do go any bigger I will for sure look into upgrading driveline I'm also working on what I want to do about the gutless 4.0
Old 02-13-2006, 06:55 PM   #20 (permalink)
More SIMEX info HAHAH looks like upgrading drive line is necessary
check it out http://home.off-road.com/~bodgerover/bodgesimex.htm
Old 02-13-2006, 07:05 PM   #21 (permalink)
Choqiees's Avatar
Simex is pretty famous all around Indonesian off-roader, or maybe around Southeast Asia...most are used for competition in Kalimantan (or Borneo) where the 96 CT was held
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 02-13-2006, 09:04 PM   #22 (permalink)
robbie's Avatar
just got the 34x10.50 LTBs and the truck is still at the shop, so no pics of that yet. i had a set of 34x9 TSLs that were on 16x5.5 wheels that stuffed very nicely into my truck with 3"+ lift and rear rte arms. 34x10.5 requires more trimming, but at this point, i really don't mind. just don't want to increase the cog anymore, so will continue to cut sheet metal to make it work. only have a few pics of the 34x9s on the truck before i sold them.
also threw in a pic of the guy's truck who bought them just because it looks so awesome.
simex-jungle-extreme-trekkers-passenger-side-smaller.jpg  simex-jungle-extreme-trekkers-small-rear-stuff.jpg  simex-jungle-extreme-trekkers-smaller-series.jpg
'95 DI
'00 DII
Old 02-14-2006, 08:04 AM   #23 (permalink)
Damn Thats HOTT alright well I can't wait to see it topless with bigger meats
Old 02-14-2006, 06:11 PM   #24 (permalink)
130CC's Avatar
I tried a set for a couple of weeks they were off a rollover with 80% left on the tred. The vibration was not that bad you did feel them through the steering wheel but only a little more that the Mickey T's. But as was said earlier the noise was unbearable a hilicoptor is a good comparison but when people hear you coming from 2 streets away and it's your tyres not your exhaust it's a bit wierd to say the least. When it came to off road f__ing great, traction is just unreall they beat the BFG Muddies and Mickey T's baja hands down no question. Lot's of fun did not buy them as I had slight rub at full articulation.
" In rivers and bad government the lightest things flow to the top" Johnny Cash
Old 02-15-2006, 03:19 AM   #25 (permalink)
rover has taken over...
hi
I ran those 32" trekker here in malaysia. They have phenomenal grip so much so that you ran the risk of crushing my rover drive shaft. It is very comon occurence here for some of the older series.Typically, people here upgreade their rover axle to a salisbury from the 109" rear axle.
If you are running the newer def or disco, then it should be okay becasue they are generally tougher.
You will love these tyre 4 sure. !
adnanlr is offline   Reply With Quote
Old 02-15-2006, 07:19 PM   #26 (permalink)
Ian Matthews
p76rangie's Avatar
This site is for the guy that designed the tyres and will be able to tell you how and where to get them.
I run JT 2's and many guys I know run them in various sizes. They do not add any real extra load on the car than any tyre of the same size. Most of the guys with Disco II's run them on a standard drivetrain without any issues.
They are a little noisey on the road, but nothing really bad. Because they are cross ply tyres they get flat stops on them when you leave the car sitting for any length of time and therefore can be a bit bumpy for a couple of miles until the flat spots disappear. The ET's are not much different to your swamper tyres, so would not see a huge advantage from Simex. The JT's are better on the road and just as good off road.
Ian
Old 02-15-2006, 07:27 PM   #27 (permalink)
Ian Matthews
p76rangie's Avatar
The 33x10.5 simex (really 34 inch) will fit under a Disco II with no guard cutting. Just require about 1.5 inch lift in the spring area. On a series 1 Disco they only need a small trim on the back bottom of the wheel arch.
Ian
Old 02-15-2006, 08:43 PM   #28 (permalink)
Ian
Do any of your people have 5"s and .... something larger?
don't mind upgrading parts just trying to get a feel for what Size I'm going to be able to fit.
Old 02-15-2006, 08:49 PM   #29 (permalink)
Anyone ever run Super Swamper Thornbirds on their truck??
Old 02-15-2006, 09:01 PM   #30 (permalink)
:)----(.Y.)
keptin's Avatar
Ehh....ive heard thornbirds are a total poseur tire.......even worse then BFG A/Ts.....an MT+AT bastard child.
Josh Shapiro
DII
