Old 01-03-2007, 08:24 AM   #1 (permalink)
New Land Rover Owner
Default Spare Tire relocator
http://www.roverparts.com/Parts/8282.cfm
is this the best price out there to mount the spare tire if you have put larger than stock tires on your D2? Has anyone made anything comparable but for less?
Thanks,
Andy
2002DiscoII is offline   Reply With Quote
Old 01-03-2007, 08:52 AM   #2 (permalink)
rmuller's Avatar
Best priced thing is to just invert your current spare tire carrier.. it'll run a 32" or 33" tire without a problem.
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
Old 01-03-2007, 09:01 AM   #3 (permalink)
Ben
TN-LR3's Avatar
but won't it put alot of stress on the rear door
1997 D-90 #1345- back to stock
2002 Dodge ram 2500CTD- dd/tow rig
looking to do 1 ton toyota or rover
TN-LR3 is offline   Reply With Quote
Old 01-03-2007, 09:04 AM   #4 (permalink)
rmuller's Avatar
Haven't heard of much complaints.. its generally when people load up the back with a hi-lift or jerry cans it'll start weakening the hinges.. but hell, I think as long as you keep them well lubed you should be fine..
I've had my spare tire bracket flipped for over 2 years without an issue. And so does the dozens of people I go wheeling with.
Old 01-03-2007, 09:11 AM   #5 (permalink)
I inverted my factory carrier 3 years ago and have had no problems with the change.
Old 01-03-2007, 09:42 AM   #6 (permalink)
does the same inverted trick apply with D1's as well?
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
Old 01-08-2007, 04:14 PM   #7 (permalink)
okay I am just now getting around to doing this, so of the original 6 screws, only 4 will be used this time as all the holes don't line up? can someone clarify this?
thanks,
andy
Old 01-08-2007, 06:10 PM   #8 (permalink)
KevinNY's Avatar
Drill new holes and use all 6.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 01-08-2007, 08:45 PM   #9 (permalink)
Choqiees's Avatar
I didn't add another 2 holes..i'm using only 4 of them. haven't got any problem so far.
but if you have the tools,drill another 2 and use all 6 bolts.
I think for D1, the tire carrier accomodates 32" with no need to invert.
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 01-09-2007, 11:39 AM   #10 (permalink)
Schattenjager's Avatar
Greetings All - new to this forum but not to Land Rovers - GREAT site by the way!
Here are pics of my stock tire carrier in it's factory position with a 235/85/16 tire (31.7" tall) and a tire cover. I used four washers between the spacer bar and the carrier at the very bottom and two in the middle. This gave a very slight angle and allows me to shut the door - tire cover and all - with no problem. IF the tire was 31.9 - I would have a problem, however...
spare-tire-relocator-tire-cover.jpg  spare-tire-relocator-tire-cover-2.jpg  spare-tire-relocator-tc3.jpg
Chance favors the prepared mind...
Schattenjager is offline   Reply With Quote
Old 01-11-2007, 06:44 AM   #11 (permalink)
antichrist's Avatar
D1 carrier will handle a 32" OD fine, close, but fine. Speaking from experience here.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 01-11-2007, 06:55 AM   #12 (permalink)
Life's Lemon
Life's Lemon's Avatar
Sweet rover schattenjager! Sorry to go off topic.. but I guess ATs do perform well in snow!
1998 Range Rover P38
http://www.myspace.com/lifeslemon
Life's Lemon is offline   Reply With Quote
Old 01-15-2007, 11:39 AM   #13 (permalink)
awe shucks....
THANKS!
