I have been a member here for ahile and I am still trying to undertand something I read here. My situation is I am driving a 94 LWB with the EAS removed. I want with a 3" lift so I am about 1 1/2" over max height if the EAS was still in. It is time for new tires. Currently running Michellin Synchro's 205/80/16. I would like to go with a 235/70/16 AT of some type. Here is where I am lost. Will this additional 1 1/4 - 1 1/2" of height srew me over as far as gear ratios and drive shafts go? This is my daily driver so no off road to speak of. I would apprecaite any insight.
Thanks, Brien
"When the going gets weird, the weird turn pro" - Hunter S. Thompson |
![]() Join Date: Dec 2005
Speaking of gear ratios, what gears to I have in my RRC LWB?
ภาษาไทย
i think rrcs have a gear ratio of 3.54. a 235/70/16 is only 0.1" taller, .8" wider, and has a circumference 0.2" bigger than a 205/80/16 so you wont have to worry about gears being off. a 3" lift may cause driveshaft vibrations so keep that in mind. the steering caster will be off so it would be wise to invest in a set of new radius arms if you feel the steering is uncomfortable.
So when a lift is applied to let's say my RRC, and driveshaft vibration occurs, what would happen during highway driving? I'd also think that U-joints would be a frequent replacement part also.
Along with that lift question, should I only consider a 2" lift over 3", for driveshaft reasons and steering reasons? I haven't done much lifting to coil spring suspension vehicles for awhile, only did shackles for leaf-spring lifts.
Thanks for all of the input. I appreciate it. The reason this became a concern was when I was on the phone with Tire Rack I was informed going from the 205/80/16 to a 235/70/16 would be a 1 1/4 to 1 1/2" increase in diameter. Since I am running a Big Blue 3" lift I was concerned about possible problems. Obviously the difference is almost nothing. The tire calculator was a huge help. The lift has been on since October and no vibration or steering issues at all. Thanks again for your help. FYI - The new tires Bridgestone Dueller A/T Revo's.
#9 (permalink) | |
Thanks for the gear ratio too! ![]()
