Old 10-18-2006, 07:07 PM   #1 (permalink)
Default Super Swamper LTB fitment
Im looking to run the LTBs in 34x10.50. However, I would like to run steel wheels with the offset. According to Interco, the LTBs need an 8" rim. I can only find 16x7 and 15x7 rims. Has anyone run this tires on a 7" rim?
War Eagle!!!
Ares is offline   Reply With Quote
Old 10-19-2006, 05:56 AM   #2 (permalink)
Wheeler
SCSL's Avatar
You will have NO problems running these tires on 7" rim. In fact, you'll probably be better off with a 7" rim. These tires run short - actual measurement is closer to 33".
Old 10-19-2006, 07:43 AM   #3 (permalink)
robbie's Avatar
as SCSL said. i currently run them on 16x7. no problems at all.
'95 DI
'00 DII
robbie is offline   Reply With Quote
Old 10-19-2006, 07:44 AM   #4 (permalink)
Put a jeep-had on you!!
LR Max's Avatar
7" is fine. My friend runs that size tire on 15x7 rims. No problems.
A narrower rim is better. When you get the tires mounted on a narrow rim. You'll notice that the tire guy is having a very difficult time getting that tire on. This generally means that the tire is going to have a difficult time getting off again. Obviously, this is a good thing.
BTW, seriously consider running airsoft pellets in your tire. It'll be better than having the tire normally balanced.
Super 109 Driver
Check out Crawl Magazine
www.crawlmag.com
LR Max is offline   Reply With Quote
Old 10-19-2006, 07:55 AM   #5 (permalink)
KevinNY's Avatar
I run them on LR 16x7 alloys, great bead retention as well.
KevinNY is offline   Reply With Quote
Old 10-31-2006, 12:58 PM   #6 (permalink)
gordo's Avatar
same here on factory alloys. Great tire but rough on the highway. Gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
