» Sponsors
» Sponsors
Old 07-02-2009, 11:08 AM   #1 (permalink)
Default Tire Wear 2000 4.6
I started to notice some outside edge only wear on my Front Right Tire and took my 4.6 Rover in for a look and rotation. The tires were rotated and toe-in adjusted at my local Britsh Car Specialist. She seemed to run smooth after.
Here I am 90 days later and after noticing a rough ride over the last 10 days I took a hard look and both REAR tires have severe wear on only the inside corners. The REAR tires were fine for an extended period before the tire rotation.
Any ideas as to possible causes? I'm having to buy a full new set a little earlier than expected and want to make certain I do not have a repeat.
Last edited by ichibanCA : 07-02-2009 at 01:04 PM. Reason: add additional information
ichibanCA is offline   Reply With Quote
Old 07-02-2009, 11:45 AM   #2 (permalink)
Super Moderator
Not knowing what year your truck is, I can't help a lot. If it has a solid rear axle, there are no adjustment so your recent alignment wouldn't cause this. If you have an independent rear, then I would say they screwed up your alignment.
Offset Spare Tire Mount bernardmann Discovery Series II 22 10-21-2008 08:52 PM
Welcome to the Discount Tire Forum (please read before posting) Discount Tire Discount Tire Direct 2 05-22-2008 11:40 AM
18X9 Wheels on my 2inch lift 95 classic tebelleh1 Range Rover Classic 9 04-23-2008 11:06 AM
What do you wear offroad? Alak Off Road 37 04-17-2008 01:51 PM
Running 35's HRees44 Range Rover Classic 119 08-20-2007 03:04 AM
