![]() Join Date: May 2005
what PSI should i use while wheeling? 15 or so??? i have a D2 with 32" BFG AT's..any advice?
Moderator of the East Coast and Discovery 2 sections! 2001 Disco II SE w/CDL ~Equipe 4x4 Winch Bumper ~Custom steel rear bumper ~Equipe 4x4 steering skid and radiator skid ~RTE rocksliders ~QT services front and rear diff guards ~2" RTE lift ~265/75 r16 Federal Couragia MTs ~Superwinch X9 ~Safety Devices Roof Rack |
It depends on what sort of surface you are wheeling on, how strong your side walls are and if you have lockers. Before I put my Detroit/T.T. in, I could roll my l/f tire bead at 18#'s in the rocks, now with the locker, the traction is not being shifted around by the ETC so much, it is more constant.
I have found that my DII, with my 3 ply 265 BFG MT's, works really well at 18#s overall, I'll go to 15 to 16#s in sand, but no lower or I can roll a bead. If you are lowering your air presure just for a softer ride and traction is not an issue, 20 to 24# is all you really need to go to. Good luck, Mike |
#5 (permalink) | |
Magicly Delicious
around 20 psi on 31x10.50x15, im probably cross axled or close to it:
Kevin Owning a Land Rover is like dating a super model. Sure she has expenive tastes, complains a lot, and requires constant attention... but damn... 1994 Discovery |
