» Sponsors
» Sponsors
Old 02-20-2009, 02:13 PM   #1 (permalink)
Rover Driver
tcpfl's Avatar
Default Wheel Alignment?
I'm not sure if this is the right place for this subject... please correct me if it's not.
Earlier this afternoon a couple of friends and I were discussing (over a pitcher of beer) whether to get a wheel alignment before or after installing new tires.. We were talking about the newer 4 wheel independent suspension LR3s, as well as, the older model D2s. With everything being computerized this or laser that these days there were certainly different opinions.
Anyway, should you get your Landrover aligned before or after installing new tires? Or does it even matter anymore?
Tom
2006 LR3 SE - Stock except for 255/60/18 General AT2s
2004 Disco II SE - 3" OME HD Springs/Shocks, Borla Cat-Back Exhaust, My Front Shaft Is A Woody, ARB Sidesteps, 255/60/18 General AT2s
2001 Disco II SE - Sold
tcpfl is offline   Reply With Quote
Old 02-20-2009, 02:22 PM   #2 (permalink)
dsfloyd's Avatar
If you were going to do an alignment and get tires I would do it after the tires. shouldn't really make a difference since alignments arent necessary unless you change suspension or steering linkage parts (or hit a big pothole),but if your doing it you might as well do it set up the way it will be used.
'60 Series II 88
'04 Silverado 2500 4x4
'02 Altima 2.5 (Hurts less at the pump)
dsfloyd is offline   Reply With Quote
Old 02-20-2009, 03:09 PM   #3 (permalink)
KevinNY's Avatar
The only thing you can adjust is toe anyway, and you can do that with a spare curtain rod and a tape measure. Good idea to check with new tires so you don't start a funny wear pattern.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 02-20-2009, 05:39 PM   #4 (permalink)
Super Moderator
Don't do an alignment unless there is a reason to.
Unusual tire wear, not from low air or lack of rotations, or pulling, not caused from low air or a separated tire belt.
Old 02-21-2009, 10:39 AM   #5 (permalink)
Rover Driver
tcpfl's Avatar
Thanks for your answers guys.
No alignment unless needed seems to be the best way to go.
Tom
Steering wheel alignment rturbett Range Rover Classic 0 10-15-2008 11:45 AM
Alignment Question DiscoSE03 Discovery Series II 1 05-21-2008 08:25 PM
18X9 Wheels on my 2inch lift 95 classic tebelleh1 Range Rover Classic 9 04-23-2008 11:06 AM
wheel alignment bcball Discovery Series I 5 05-20-2006 09:09 AM
