#16 (permalink) |
I found these on Ebay - not exactly a spacer but gives you the option to go to a P38 (95-02) or DII (98-04) bolt pattern giving you more options for wheels. Although they are a bit pricey at 1200. They appear to be hubcentric as well.
"He who has a 'why' to live, can bear with almost any 'how'." - Friedrich Nietzsche (1844-1900) |
#17 (permalink) | |
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
#18 (permalink) |
I've run spacers on my DII for about a year and half, with no problems. As to the tightening required, they should only need about 2 tightenings before they stay put. Just like buying new rims for your car, the aluminum is soft and you should tighten the lugs after the first 50 miles and then after 100 miles. After that you should be good. When I did this with my aluminum spacers, I never had to tighten them again. And x2 on no difference between a wheel with an offset and spacers.
#19 (permalink) | |
It would more strain on our already questionable and expensive hubs and it will greatly increase your turning radius. Mike |
#20 (permalink) |
No sparky, it REDUCES your turning radius by giving you more clearance to your radius arms, particularly with oversize tires. LR hubs are neither expensive or fragile.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. '91 RRC, bone stock |
#21 (permalink) |
And spacers aren't going to add any more strain than an additional 2" offset rim would.
#22 (permalink) |
I have spacers on my other two 'new' cars.
Porsche Boxster S has 8mm in front, 16mm rear Range Rover Classic has 30mm all aroundNo problems for years of use at high speeds, low speeds, or offroading. I recently asked my mechanic whether my 1975 Series III would have any issue with spacers and he gave me the same mumbo jumbo I've read in this thread. I posted a similar question on the Series forum and got mixed opinions. I'm going to disregard the negatives as I now believe some people are just 'anti-spacer' - I plan to put them on my Series too.
'75 Series III 88" '90 RRC SWB |
#23 (permalink) | |
For dedicated offroad trucks, wheel angle (decreased turning radius) is increased by changing the geometry of the pittman arms. On series trucks, there were two methods which worked equally well. One used a shorter upper relay arm, the other used a longer lower relay arm. On Rangies, Discos and Defenders, there was a cross reference to a steering box pittman arm that was about an inch longer. The trade off was increase steering sensitivity, but for offroaders, that wasn't so much an issue as it would be on the highway (especially on series trucks which like to wander a bit anyway) Any increase in wheel angle will require either wider offset rims or spacers. A given turning radius is determined by two things; the amount of angle the front wheels can make, and the wheelbase (the rear wheel spacing has nothing to do with it, since the pivot point is still the center of the two rear wheels). |
