Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only General Forums > Tech & DIY
Closed Thread
Old 01-26-2007, 08:00 AM   #1 (permalink)
TerryS's Avatar
Default [All] Pre 96 OBD1 Fault Codes
Land Rover
OBD1 pre-96
READING FAULT CODES (USA only)
The Engine Control Module (ECM) is capable of storing fault codes. For U.S. vehicles, these fault codes may be read by switching the ignition switch to position II and observing the fuel injection fault display unit, which is located underneath the right hand front seat, adjacent to the ECM.
NOTE: Image shows display unit with trim removed.
If no codes are present, the display will appear blank. A constantly lit Check Engine warning light indicates that a fault is present.
Put the ignition switch in position 0 and wait till the load relay drops out.
Put the ignition switch in position II. The display will be blank if no other faults exist. If other codes exist, the next fault code will be displayed.
If multiple faults exist, repeat steps 1 through 3 until all faults are cleared.
Code 02 indicates that the ECM has just been reconnected. Switch the ignition switch to position II to clear code 02.
For non-U.S. vehicles (not equipped with a fuel injection fault display), the Lucas diagnostic equipment, part number 60600965, is recommended for reading fault codes.
How to Clear Diagnostic Trouble Codes
CLEARING FAULT CODES (USA only)
When a fault has been corrected, the fault code must be cleared. This is done by performing the following procedure:
Disconnect the Data Link Connector (DLC) , which is located behind R/H side of dash, and wait 5 seconds. Reconnect data link connector.
If multiple faults exist, repeat steps 1 through 4 until all faults are cleared. NOTE : Code 02 indicates that the Engine Control Module (ECM) has just been reconnected. Switch the ignition switch to position II to clear code 02.
Code
Circuit Or Condition
02
Battery Recently Disconnected
03
ECM Memory Recently Cleared
12
MAF Sensor
14
ECT Sensor
15
Engine Fuel Temperature Sensor
17
Throttle Position Sensor
18
Throttle Position Sensor/Mass Air Flow Sensor
19
21
Fuel Tune Select Resistor
23
Fuel Supply
25
Ignition Misfire
28
Air Leak
29
ECM Memory Check
34
Injector Bank A
36
Injector Bank B
40
Misfire Left Bank
44
HO2S Left Bank
45
HO2S Right Bank
48
Idle Air Control Valve
50
Misfire Right Bank
59
Group Faults 23/28
68
Vehicle Speed Sensor
69
Park/Neutral Position Switch
96 - up OBD2
With Generic OBD II Scan Tool
When an OBD II fault occurs in Land Rover's Generic Engine Management System (GEMS ), the Malfunction Indicator Lamp (MIL ) is illuminated. GEMS Diagnostic Trouble Codes (DTC ) are stored in the Engine Control Module (ECM ) and may be retrieved by connecting a suitable OBD II Scan Tool or the Land Rover TestBook Electronic Tester to the Data Link Connector (DLC ).
The DLC is located at the passenger side footwell.
DTC's can only be Extracted, Diagnosed and Cleared by the TestBook Diagnostic Unit, a required special tool , or an appropriate after market equivalent.
All information regarding DTC's for this model is contained within the Land Rover TestBook Diagnostic Unit. The manufacture does not provide any other information on How to Pull Codes, Trouble Code Descriptions, Diagnosis and Testing of Trouble Codes or How to Clear codes.
DIAGNOSTIC TROUBLE CODES
*Codes* are used to identify the 4 Oxygen Sensors.
A = Bank A of the engine. Cylinder #1 is located on Engine Bank A.
B = Bank B of the engine.
U = Upstream of the Catalytic Converter.
D = Downstream of the Catalytic Converter.
Example:
A D = Oxygen Sensor Engine Bank A, Downstream of Catalytic Converter.
TROUBLE CODE CHART
P0101
Mass Air Flow Sensor Signal Error Fault
P0102
Mass Air Flow Sensor Low Out of Range Fault
P0103
Mass Air Flow Sensor High Out of Range Fault
P0111
Air Temperature Sensor Signal Error Fault
P0112
Air Temperature Sensor Low Out of Range Fault
P0113
Air Temperature Sensor High Out of Range Fault
P0116
Engine Coolant Temperature Sensor Falling Temp Fault
P0117
Engine Coolant Temperature Sensor Low Out of Range Fault
P0118
Engine Coolant Temperature Sensor High Out of Range Fault
P0121
Throttle Position Sensor Output Signal Error Fault
P0122
Throttle Position Sensor Low Out of Range Fault
P0123
Throttle Position Sensor High Out of Range Fault
P0125
Engine Coolant Temp Sensor Warm Up Fault
P0130
Oxygen Sensor Cycle Fault *Codes* A U
P0131
Oxygen Sensor Low Voltage *Codes* A U
P0132
Oxygen Sensor High Voltage *Codes* A U
P0133
Oxygen Sensor Slow Response *Codes* A U
P0136
Oxygen Sensor Cycle Fault *Codes* A D
P0137
Oxygen Sensor Low Voltage *Codes* A D
P0138
Oxygen Sensor High Voltage *Codes* A D
P0139
Oxygen Sensor Slow Response *Codes* A D
P0150
Oxygen Sensor Cycle Fault *Codes* B U
P0151
Oxygen Sensor Low Voltage *Codes* B U
P0152
Oxygen Sensor High Voltage *Codes* B U
P0153
Oxygen Sensor Slow Response *Codes* B U
P0156
Oxygen Sensor Cycle Fault *Codes* B D
P0157
Oxygen Sensor Low Voltage *Codes* B D
P0158
Oxygen Sensor High Voltage *Codes* B D
P0159
Oxygen Sensor Slow Response *Codes* B D
P0171
Oxygen Sensor System Too Lean Fault Bank A
P0172
Oxygen Sensor System Too Rich Fault Bank A
P0174
Oxygen Sensor System Too Lean Fault Bank B
P0175
Oxygen Sensor System Too Rich Fault Bank B
P0181
Fuel Temperature Sensor Signal Error Fault
P0182
Fuel Temperature Sensor Low Out of Range Fault
P0183
Fuel Temperature Sensor High Out of Range Fault
P0201
Injector 1 Circuit Fault
P0202
Injector 2 Circuit Fault
P0203
Injector 3 Circuit Fault
P0204
Injector 4 Circuit Fault
P0205
Injector 5 Circuit Fault
P0206
Injector 6 Circuit Fault
P0207
Injector 7 Circuit Fault
P0208
Injector 8 Circuit Fault
P0300
Misfire On Multiple Cylinder
P0301
Misfire Cylinder 1
P03O2
Misfire Cylinder 2
P03O3
Misfire Cylinder 3
P0304
Misfire Cylinder 4
P0305
Misfire Cylinder 5
P0306
Misfire Cylinder 6
P0307
Misfire Cylinder 7
P0308
Misfire Cylinder 8
P0326
Continuous Knock Fault Bank A
P0327
Background Noise Low Fault Bank A
P0328
Background Noise High Fault Bank A
P0331
Continuous Knock Fault Bank B
P0332
Background Noise Low Fault Bank B
P0333
Background Noise High Fault Bank B
P0335
Crankshaft Position Sensor Signal Error Fault
P0336
Crankshaft Position Sensor Out of Range Fault
P0340
Camshaft Position Sensor Signal Error Fault
P0420
Catalyst Efficiency Low Fault Bank A
P0430
Catalyst Efficiency Low Fault Bank B
P0441
Evap Purge Valve Incorrect Flow Fault
P0442
Evap System Small Leak Detected Fault
P0443
Evap Purge Valve Open or Short Circuit Fault
P0451
Fuel Tank Pressure Sensor Signal Error Fault
P0452
Fuel Tank Pressure Sensor Low out of Range Fault
P0453
Fuel Tank Pressure Sensor High Out of Range Fault
P0461
Fuel Tank Level Measurement Not Valid Fault
P0500
Vehicle Speed Sensor Signal Error Fault
P0506
Idle Speed Control Engine Speed Low Fault
P0507
Idle Speed Control Engine Speed High Fault
P0560
Battery Voltage Below Minimum Fault
P0562
Measurement Circuit OK Battery Voltage Low Fault
P0563
Battery Voltage Above Maximum Fault
P0605
ECM Self Test Fault
P1130
Oxygen Sensor Fuel Trim at Limit *Codes* A U
P1131
Oxygen Sensor Engine Lean *Codes* A U
P1132
Oxygen Sensor Engine Rich *Codes* A U
P1137
Oxygen Sensor Engine Lean *Codes* A D
P1138
Oxygen Sensor Engine Rich *Codes* A D
P1150
Oxygen Sensor Fuel Trim at Limit *Codes* B U
P1151
Oxygen Sensor Engine Lean *Codes* B U
P1152
Oxygen Sensor Engine Rich *Codes* B U
P1157
Oxygen Sensor Engine Lean *Codes* B D
P1158
Oxygen Sensor Engine Rich *Codes* B D
P1171
Oxygen Sensor System Too Lean Fault Banks A & B
P1172
Oxygen Sensor System Too Rich Fault Banks A & B
P1176
Maximum Positive FMFR Correction Fault
P1177
Maximum Negative FMFR Correction Fault
P1178
Maximum Positive AMFR Correction Fault
P1179
Maximum Negative AMFR Correction Fault
P1185
Oxygen Sensor Heater Circuit Open Upstream
P1186
Oxygen Sensor Heater Circuit Short Upstream
P1187
P1188
Oxygen Sensor Heater High Resistance Upstream
P1189
Oxygen Sensor Heater Type 1 Low Resistance Upstream
P1190
Oxygen Sensor Heater Type 2 Low Resistance Upstream
P1191
Oxygen Sensor Heater Circuit Open Downstream
P1192
Oxygen Sensor Heater Circuit Short Downstream
P1193
P1194
Oxygen Sensor Heater High Resistance Downstream
P1195
Oxygen Sensor Heater Type 1 Low Resistance Downstream
P1196
Oxygen Sensor Heater Type 2 Low Resistance Downstream
P1199
Fuel Level Sensor Circuit Fault
P1201
Injector 1 Open Circuit or Ground Short Fault
P1202
Injector 2 Open Circuit or Ground Short Fault
P1203
Injector 3 Open Circuit or Ground Short Fault
P1204
Injector 4 Open Circuit or Ground Short Fault
P1205
Injector 5 Open Circuit or Ground Short Fault
P1206
Injector 6 Open Circuit or Ground Short Fault
P1207
Injector 7 Open Circuit or Ground Short Fault
P1208
Injector 8 Open Circuit or Ground Short Fault
P1313
Misfire Catalyst Damage Fault Bank A
P1314
Misfire Catalyst Damage Fault Bank B
P1315
Misfire Persistent Fault
P1316
Misfire Excessive Emissions Fault
P1317
ABS Rough Road Line Low Fault
P1318
ABS Rough Road Line High Fault
P1361
No Ignition Coil Activation Fault Coil 1
P1362
No Ignition Coil Activation Fault Coil 2
P1363
No Ignition Coil Activation Fault Coil 3
P1364
No Ignition Coil Activation Fault Coil 4
P1371
Early Ignition Coil Activation Fault Coil 1
P1372
Early Ignition Coil Activation Fault Coil 2
P1373
Early Ignition Coil Activation Fault Coil 3
P1374
Early Ignition Coil Activation Fault Coil 4
P1440
Evap System Purge Valve Stuck Open Fault
P1441
Evap System Purge Valve Flow 1 Fault
P1442
Evap System Purge Valve Blocked Fault
P1447
Evap System Purge Valve Open or Short Circuit Fault
P1448
Evap System Purge Valve Flow 2 Fault
P1508
Idle Speed Control Open Circuit Fault
P15O9
Idle Speed Control Short Circuit Fault
P1514
Neutral Drive Load Fault
P1516
Neutral Drive Gear Change Fault
P1517
Neutral Drive Cranking Fault
P1607
Malfunction Indicator Lamp Short Circuit Fault
P1608
Malfunction Indicator Lamp Open Circuit Fault
P1620
Reprogramming Code Learn Fault
P1621
Serial Data Link Dead Fault
P1622
Repeated Wrong ECM Security Code Fault
P1623
P1701
Transfer Box Line Fault
P1703
Transfer Box Line Open Circuit Fault
P1708
Transfer Box Line Short Circuit Fault
P1775
Gearbox Fault
P1776
Gearbox Ignition Retard Request Timeout Fault
P1777
Gearbox Ignition Retard Request Line Fault
TerryS is offline
Closed Thread
