» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only General Forums > Tech & DIY
Closed Thread
Old 05-28-2007, 08:21 PM   #1 (permalink)
Default If your key gets stuck in the ignition, do this
Turns out my park switch isn't always engaging which leaves the key stuck in the igition. I found the mechanism that prevents you from removing the key. You can manually push it out of the way once you take the steering wheel cover off. No tools are required. Its the object in the very center of the pic.
in the normal mode,
in stuck key mode.
I was getting so irritated, I was about to take a pipe wrench to the key and force it =) But under the steering wheel cover, under another cover I found a solenoid, and discovered my problem. Hmm, maybe thats why they call it the discovery!
etischer is offline
Old 06-12-2007, 06:07 AM   #2 (permalink)
Captain Ducman's Avatar
Default reminds me of the time....
Thanks good info.
It makes me chuckle because a few weeks ago my wife took my DII to work cuz I wanted the convertible for the day. She calls me all upset when she gets to work that she cant get the key out of the ignition. I tell her the standard, move the steering wheel, push the key in while turning...yada yada.
Then it occurs to me...."uhhhh honey, do you have it in PARK?"
Problem solved.
Yes she's blonde but way smarter than this story portrays.
Duc
Captain Ducman is offline
Old 08-06-2007, 11:44 AM   #3 (permalink)
Default what part in the pic specificallly do
you move out of the way? Anyone?
Ruminator is offline
Closed Thread
