» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Other > New Member Introductions
Old 09-29-2008, 07:42 AM   #1 (permalink)
rawlydog600
Default fast idle
hello my name is Bill I am new to this forum.I assume this has been asked before.I have a 97 disco se the check engine light was on I fixed some vacuum issues cleared the light again and since the idle is about 1500-2500 i changed the IACV when i unplug the mass air the idle drops for a second then picks back up same with throttle position sensor please help if you can.also the actron obd says there are 0 faults.
rawlydog is offline   Reply With Quote
Advice on setting base idle norville Range Rover Classic 7 09-26-2009 03:12 AM
Idle Control Valve - idle problems; get to know it glenncof Range Rover Classic 2 02-24-2008 01:57 PM
correct procedure for setting base idle? deadboy1977 Range Rover Classic 0 12-11-2007 01:11 PM
Rough Idle while in Gear? 95' RRC husaberg450 Range Rover Classic 4 03-11-2007 08:44 PM
Temperamental Idle texasrover Discovery Series I 1 12-23-2004 09:33 AM
