» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Other > New Member Introductions
Old 10-01-2008, 10:29 AM   #1 (permalink)
Default Hello From Manitoba!
Hey guys. Was looking for Discoweb and couldn't get it to come up on the net. Looks like you guys are the new replacement. Anyway, having some mechanical issues and need new tires for Disco II so I thought I'd drop in to see what's up.
I went by xtravrt on Discoweb.
My rig is a black 2002 Disco II with RTE Front bumper/skid assembly, RTE Sliders, RTE 3" lift with Blistein Remote Reservoir shocks, 265/75R16 BFG MT's, Superwinch 9000, Dual Optima Batteries, 3 Lightforce XGT Driving lights, CB, Hannibal Roof Rack and Jerry Can Holders, Technitop Roof Tent, etc., etc.
I'm thinking of going to 285's. Apparently they will fit but I might need to trim the front ends of the rock sliders off a bit. Might try them without since I just had the bumper, skid and sliders re-powder coated. The stock powder coating sucks the bone. I have been having problems with my rear pinion seal (I think that's what the point is where the drive shaft meets the rear diff) regularly leaks and needs to be fixed (once every year or so) so I'm not sure how much more of a problem the drive line will face with 285's since it's already having probs with 265's.
Anyway, also have a leaking head and three a piston 6 code. Think antifreeze has gotten in there. I still have extended warranty to end of October so hopefully it gets sorted out. Any pointers on that issue welcome.
Thanks all!
Riflman
Riflman is offline   Reply With Quote
Old 10-01-2008, 11:44 AM   #2 (permalink)
got mud?
Jupiter Rover's Avatar
Discoweb was down a week ago, then up for a couple days.. Now it has been down for a while. They need to fix their server.
I run 285s on my DII with no drivetrain problems, however I drive real easy on the skinny pedal. It also depends on what kind of terrain you wheel on. If you're on rocks you may need some stronger driveshafts. Your rear driveshaft issue is most likely because of the RTE 3" lift not the 265s.
I would put the tires on and see IF they rub the sliders. Every rig is different.
Pete
2003 DII CDL equipped
33" Destination M/Ts
Old 10-01-2008, 12:02 PM   #3 (permalink)
I'm rarely on rocks. No mountains here to speak of. Mostly Red River Gumbo or MUD. Lots of swampy gunk in the prairies that gets you down to the diffs in a hurry. Any advice on how to fix the recurring drive line prob with the RTE lift?
Old 10-01-2008, 12:05 PM   #4 (permalink)
Steve from RTE said they will only rub on full tuck. I don't full tuck very often because we're mostly flat here. Will 285's increase drive line problem or just increase the chance of broken axles and suck more power from the truck due to stock diff gearing?
Old 10-01-2008, 02:15 PM   #5 (permalink)
got mud?
Axles won't break unless you lock the diffs. You may need an extended Rear driveshaft. Call Bill at GBR and ask him. He will know what the problem is. His number is on this site. Great Basin Rovers - navbar I wheel in the same terrain and haven't had any problems. Some other guys on Dweb run 285s with stock gears ect. with no problems.
Pete
Old 10-07-2008, 09:30 AM   #6 (permalink)
alrom.ca
Discocarlos's Avatar
Hello there I'm also from MB it seems that there is more and more people buying Rovers now i have a friend that has a green Series II he works for St James VW and another guy that is in Lorette that has a collection on his backyard, is there anybody else from Manitoba in here?
Discocarlos is offline   Reply With Quote
Old 10-12-2008, 09:41 PM   #7 (permalink)
Another one here from winnipeg. I have two 1966 ser IIs. One is in the rebuild stage.
WPGSERIES is offline   Reply With Quote
Old 10-14-2008, 07:46 AM   #8 (permalink)
98xc800's Avatar
Gillam, Manitoba here, But in Winnipeg about a week a month.
I have been starting to see more Discoverys around lately. I guess the reasonable prices of them used makes more people look at them.
Personally, I looked at what people in the Outback and the wilds of Africa drive. The roads up here are quite similar, and you can be as far from service as those places, so I need something reliable and rugged. The luxury of it sold it to my Wife.
99 D2
31x10.50/15 Pro Comp XTerrains on BMW steel 15x6.5 wheels.
98xc800 is offline   Reply With Quote
Old 10-14-2008, 10:10 AM   #9 (permalink)
alrom.ca
Nice more Manitoba L.R Owners
