Originally Posted by brian4d
Wrong, an OBDII scanner will not pull the ABS fault codes. You need a dealer or indy to pull the codes with a testbook or whatnot. Or find someone in your area with the ABS amigo.
True, on the ABS codes, thus option one. It seems we preech alot of "get the codes" that's the direction I was going. Based on the all 3Amigos posts, it could be many things other than an ABS fault. Testbook could clear them and they never return, it could be a low voltage battery....... I had a so called expert (Independent) tell me without hesitation it was my ABS shuttle valve, nope he was wrong..many variables that is for sure. I should buy an ABS Amigo and share it for postage and handling.
Link to the ABS Amigo.
Land Rover Reset Tools - ABS Amigo
Just trying to welcome a new owner. Thanks for the blast.
