Land Rover LR3 - Land Rover Forums : Land Rover and Range Rover Forum
 2Likes
  • 1 Post By rrand
  • 1 Post By redtruck12
post #1 of 8 (permalink) Old 03-11-2017, 10:42 AM Thread Starter
Quoted: 0 Post(s)
Land Rover LR3
Our land Rover has a few problems. 1. It says that the bonnet is open when it's not. 2. After putting in new brake pads and sensors it won't go into drive. The shifter won't click into place. Any advice? Thanks!
Penny is offline
post #2 of 8 (permalink) Old 03-11-2017, 01:42 PM
Quoted: 6 Post(s)
There is a latch sensor(switch) for the bonnet (hood) that may need adjusting or replaced. Also you may have issues with the alarm caused by the bonnet sensor.
On the brake system, it may be the pedal switch or something simple. When the brake is depressed, the switch engages and release the shift mechanism.
Penny likes this.
rrand is offline
post #3 of 8 (permalink) Old 03-11-2017, 03:28 PM
Special Agent
redtruck12's Avatar
Quoted: 121 Post(s)
Garage
I can't imagine any relation between brake pads and sensors and going into gear.
Front brakes? Only a sensor on the drivers side and there are a couple other wires in the area where it connects to the harness. Something else bumped??????
The hood switch is located on the passenger side hood latch and is a serviceable switch. As a quick test of the circuit, you can disconnect the wiring plug and cross the connections (a paper clip works) this is a grounding circuit so no danger of hurting anything.
Dash warning should go off.
Any other fault messages on the display?
Penny likes this.
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #4 of 8 (permalink) Old 03-13-2017, 04:34 AM
tomai79's Avatar
Quoted: 0 Post(s)
Welcom,nice to meet you.
tomai79 is offline
post #5 of 8 (permalink) Old 03-19-2017, 08:50 AM Thread Starter
Quoted: 0 Post(s)
Thanks for helping. It might have something to do with hill decent control. It will lock into reverse but not drive. Also, I still can't fix the bonnet is open. Would you be able to share a video or pictures?
Penny is offline
post #6 of 8 (permalink) Old 03-19-2017, 08:59 AM Thread Starter
Quoted: 0 Post(s)
A while back it had a message about hill decent control . I still can't get it into drive or get rid of the bonnet is open message
Penny is offline
post #7 of 8 (permalink) Old 03-19-2017, 09:36 AM
Quoted: 290 Post(s)
Do you have operating brake lights? These vehicles have a solenoid that when closed, locks the gearshif into park. It's controlled by the brake light circuit. Not sure on this specific truck, but some will go into neutral with the key in first unlocked position, which is wheel unlocked, nothing on. There also may be a manual release. The older Rovers required the plate below the shifter to be popped up and the solenoid manually disengaged. Check your manual for the release procedure.
CT090 is offline
post #8 of 8 (permalink) Old 03-20-2017, 11:51 AM
sierrafery's Avatar
Quoted: 57 Post(s)
The bonnet switch's pic is attached, i dont know exactly how it is on D3 but usually for the alarm the bonnet switches are open when the bonnet is closed and close to earth when it's opened so the message might dissapear if you simply unplug it but if not as @redtruck12 said bridge the pins in the plug...if still no joy then it's a wiring issue on that circuit
Name:	D3 bonnet switch.jpg
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
ALL MY ADVICES ARE BASED ON MY OWN EXPERIENCE AND MY WAY OF UNDERSTANDING THE DESCRIPTION AND OPERATION OF SYSTEMS NOT OFFICIAL METHODS... I'M NOT A LAND ROVER TRAINED SPECIALIST JUST AN ADDICTED ENTHUSIAST.
sierrafery is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only Other > New Member Introductions
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
OEM Land Rover LR3-LR4-Range Rover Sport Winch Kit w/ Warn 9.5XP milemarker60 Land Rover Parts and Accessories 2 03-11-2016 11:15 AM
Land Rover LR3 / LR4 - Range Rover Sport Hitch - $250 Crabby LR3 Land Rover Parts and Accessories 4 08-21-2014 10:17 AM
2008 Land Rover LR3 S/C Sport Land Rover Vehicles 2 10-16-2010 12:36 PM
New to Land Rover & LR3 Bullhead Discovery 3 / LR3 2 09-11-2010 03:23 AM
Land Rover LR3, Range Rover P38a and an RRC - Off roading with RoverTym at Uwharrie Dantelaterra Off Road 11 08-12-2009 08:31 PM
You may post new threads
You may post replies
