» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Other > New Member Introductions
Old 09-14-2009, 01:15 PM   #1 (permalink)
Default Michelin Latitude Tyre Vibration
Hello
I've just had two Michelin Latitude Tour HP 215/65 R16 H (102) tyres fitted to my three year old Freelander TD4 2.0ltr Auto Freelander, as rec' by local dealer, replacing two Synchrone's (same spec') that were fitted from new, ahead of the vehicles first MOT. The vehicle now has it's original Sychrones on rear and Latitudes on front.
(Michelin have replaced Synchrone's with Latitude's apparently)
With the new config' I have also gained a vibration at approx' 30mph thru to 55mph (incl. extra road noise). I was told by Black Circles (the supplier) that this was common on Freelanders and should have replaced all four tyres to eradicate the problem.
I'm no scientist and sounds v.odd to me. Has anyone else experienced this issue?
ForestFree is offline   Reply With Quote
Old 09-26-2009, 11:07 AM   #2 (permalink)
Default Put new tyres on REAR
Hi you say the new tyres are now on the front ??
That is were your problem is as you should NEVER put new tyres on the front of a Freelander.
Landrover insist new tyres on REAR because of the drive ratios to the rear wheels, if you put new on the front it will cause the viscous coupling to overwork causing a wind up of the transmission system resulting in failure of either vc , Ird or rear dif because of the increased circumference of the new tyres.
Put your 2 new tyres on the rear straight away and problem should be solved.
championsom is offline   Reply With Quote
Old 09-26-2009, 01:37 PM   #3 (permalink)
Chuck A's Avatar
Gallery: 5
hello and welcome
Chuck A is offline   Reply With Quote
Old 09-27-2009, 06:42 AM   #4 (permalink)
Super Moderator
Originally Posted by ForestFree View Post
Hello
You will get more replys if you post your question in the Freelander section.
Michelin Latitude Tourings HP All Season Luxury HP 255/65 R16 109H roni Land Rover Parts and Accessories 0 02-10-2009 01:50 PM
