Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Other > New Member Introductions
Old 01-09-2008, 06:12 PM   #1 (permalink)
rangeshort
Exclamation New 1997 RR 4.6hse from FLA in the USA
Hi, I just bought a box of wires. A 1997 RR 4.6HSE w/45k miles on it. However, it is a puzzle. When the battery is hooked up ALL of the warning lights run as well as a ventilation fan. This is without the key in the ignition
When the key is inserted and turned, the beep beep beep sounds and then changes a little but continues. The Gauges do not function at all-all pegged on zero. The message center display does not function. The suspension lights flash and then go steady while the suspension stays slammed on the bump stops. The passenger seat is removed exposing the BECM. I checked the ignition switch and it acts the same with the switch unplugged. I pulled the becm cover and boards. No sign of damage or heating whatsoever. I can pull connector C256 or C258 and the lights go out. I can pull the main ground wire off of the BECM and there is still 12V between the empty lug and the + bat wires. The vehicle starts and runs, locks, sunroof, seats, wipers alarm, ac and transmission all function. Any ideas? I am thinking that either one of the mosfets in the BECM is bad or there is a ground wire that is hardwired or perhaps a bad cluster or bad becm
rangeshorter is offline   Reply With Quote
1997 Land Rover Discovery XD, Limited Edition of 250 mkormov Land Rover Vehicles 3 05-01-2007 11:18 AM
1997 Discovery XD Serg Land Rover Vehicles 45 02-09-2007 08:47 AM
Anti Freeze Reservior Cap - 1997 Disco Series I LRXD Land Rover Parts and Accessories 0 10-28-2005 03:26 PM
1997 Range Rover 4.0SE(71k miles) for sales golfpro Land Rover Vehicles 0 10-18-2004 01:17 PM
1997 Discovery Se7 For Sale hopsonschoice Land Rover Vehicles 0 08-09-2004 05:04 PM
