Originally Posted by RoveReady
I recently bought my series 2 and want to convert it into a trail animal. I am looking at H.D 3'' lifts and want to put it onto some 285s. The truck was well maintained but it sits at 100 thousand miles. I do not know to much about the Land Rovers abilitys and weak points yet, but have always wanted to get into one and build one. If i go to 285s will i need a new T.C? and axles?
Rovertym and OME (old man emu) are your best choices for the lift. the 285's will be at the limit some will tell you of your axles capabilities. I've been running 33's for about 6 months now with no problems yet. Your transfer case will be just fine with the tires.
thanks for you help and for writing back. i have now tossed some 3 inch blocks and some 285s on. i wish i could go bigger but o well for now. it feels good but the tires i got on now arnt to aggresive
3 in spacers for the lift? I wouldn't recommend that course of action as with worn springs and that thick of spacer your setting yourself up for disaster. This is what most people refer to as a bad idea.
Do a proper lift you'll be better off in the long run. Unless of course your talking about an old series truck and not a Disco series 2
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
