Hello : XtremeMarine
like I mention before I live in a hot dry desert (palm springs ca.)
if it doesn't take alot of moisture for RUST/SCALE/PITTING of the 4.6 engine. how much moisture (water)will it take for internal corrosion the sleeve and piston to look like they have been under salt water for long time the taken out and sand blasted to be clean up
beacuse that is what the pictures show (pictures send to me) by JOHN MILLER @TIDEWATER ROVERS in WILMINGTON NC.
I send back the engine for warranty repairs to JOHN MILLER@TIDEWATER ROVERS
1) intake gasket (valley pan gasket inflation) poping when the engine was turn on and when it was turn off and leaking at the rear of the engine
2) lost of compression from 115-135psi to 95-115psi with in 2500 mls on a rebuild engine
3) clicking sound on the engine like a lifter or a valve
4) leaking freeze plugs the point that i was able to beack some of the crust away with my fingers
TIDEWATER FROVERS (JOHN MILLER) answers
1)the intake gasket was poping because the cranckcase vent tube where block (plug)
(cranckcase ventilation only has two vent tubes one on each valve cover. one has a new baffle the other don't)
2) on the compression, he had done 3 test and was able to get over 200psi there for the compression was not a problem.
..............with the RUST/SCALE and HEAVY PITTING of the CYLINDER SLEEVE/PISTON and HEADS .................. how can this be possible.......
3) on the clicking sound JOHN MILLER@TIDEWATER ROVERS believe the oil pump (oil pump gear set)needed to be replaced because it was not providing enough oil pressure to the engine.
(the oil gear set and the timing chain where replaced with new ones)
he request to show proof of evidence.
(i fax him the invoice from british pacific land rover parts together with compression test print out. from 2 different places one from a new car dealer and other one from a local repair shop)
4)on the freeze plugs JOHN MILLER said that all engines leak at the freeze plugs and eventually the seal them selfs and do to the amounth of antyfreeze crust over the plugs they have seal them selfs there for it was no longer a problem. any repairs done to the engine will not be under warranty.
last night I taken the 4.0 engine out of the same type of plastic container like the 4.6 engine came with from TIDEWATER ROVERS for RUST/SCALE and PITTING inspection
after been in my garage for 6 months but there is no trace of RUST/SCALE or PITTING
on any part of the 4.0 engine
