Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Other > New Member Introductions
Old 11-18-2007, 03:39 PM   #1 (permalink)
Banzai Jimmy's Avatar
Default Posting up from CO on new account
I figured I'd better post up or else have something happen to my account! I don't think I ever posted up from the last one I had here, so it was useless when I actually went to use it.
Many from CO will know me. Hope to meet more of you.
Here's to getting out and wheeling!
'94 DI - 3" RTEs, Foxs, 33s, ARB lockers, MDE rears, LongTracks fronts, D110 t-case w/MDE crawler gears, skids throughout, and an M10000 for when the times get tough.
Banzai Jimmy is offline   Reply With Quote
Old 11-18-2007, 03:41 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
Hey Hey!!
Old 11-18-2007, 03:50 PM   #3 (permalink)
Already get that trailing arm swapped out?
I had my Rockware arms out a few weeks back to get new bushings pressed in at JC Rovers, and was talking to Jeff about how they do pinch the upper bushings a bit since the bend isn't enough for a 3" lift (probably would be perfect for a 2"). So, Jeff turns me loose on a bender to add a little bit more to it. As I was giving the second arm a little more pressure in order to match the first one that was already done, I feel the tube give under the pressure It cracked on the top side... so out with the welder to weld up the crack and then I welded in a brace on the bottom side to help keep it from flexing enough to tear the new welds on top.
Always has to be something!
Old 11-18-2007, 04:07 PM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
I am actually going with rovertracks!!!!! But I have the OEM one ready to instal!!
Old 11-18-2007, 09:30 PM   #5 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Hey Jimmy!
Jim Hall
obstacle.” Michael
jimfoo is online now   Reply With Quote
Old 11-19-2007, 05:08 AM   #6 (permalink)
Originally Posted by jimfoo
Hey Jimmy!
Hey Jim! Things have been quiet on the Solihull board recently - I guess it's that time of the year. Did you figure out what happened to the engine in the Elephant Chaser?
