» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Other > New Member Introductions
Old 03-10-2009, 04:48 AM   #1 (permalink)
Default From TJ to Disco?
Hey all!
Well I found this site to help me make an informed decision in my next wheeling vehicle. I've had a TJ (Wrangler) for a while, but I sold it to buy a Jeep Patriot for the commute. However, I miss my TJ terribly. After looking on the local Cragslist (Las Vegas) for a new 4X4, I stumbled across an '01 Disco II. Ive always had a thing for Land Rovers and thought this might be a good place to get some answers.
As far as "out of the box" capability, which model is best for climbing and trails? Ive seen the discos and ranger rovers, as well as the "out of my league" defender, but I also see that they have a new model, the freelander.
Second question: Which will take the least amount of money to upgrade. Im not talking about a complete suspension overhaul, but which one with the most basic upgrades (lift and such) will cost the least. Ive seen some discos go for around 4k-6k with a little less then 80K miles. I would like to stay in the lower spectrum of that range when it comes to purchasing a vehicle, but am willing to pay more for the upgrades.
I know this is a very vauge and general question, but I still have a good amount of reading in front of me to get aquainted with these fine rides.
Again thanks in advance all!
Makrinos001 is offline   Reply With Quote
Old 03-10-2009, 06:16 AM   #2 (permalink)
Reptile Expert
04 disco would be a great year from the discovery model to hit the trails in.
www.cardomain.com/ride/2650472/
www.fortmyersracing.net
www.cafepress.com/stolenheron
stolenheron is offline   Reply With Quote
Old 03-10-2009, 07:13 AM   #3 (permalink)
RussRover's Avatar
Gallery: 1
x2 on the 2004 disco. equipped with the CDL. plus, there are alot of aftermarket parts for the disco
2004 Disco SE7 - Totalled
2002 330 ci
www.discounttiredirect.com
RussRover is offline   Reply With Quote
Old 03-10-2009, 12:39 PM   #4 (permalink)
got mud?
Jupiter Rover's Avatar
Originally Posted by Makrinos001 View Post
Hey all!
Get a 2004 DII. It comes with the 4.6, Centre Diff lock, and a great Traction control system. It is also the last year for that specific model. Discovery IIs are much easier to lift and fit larger tires than a Discovery I. Plus it is a Newer vehicle (year wise) so many still have warranty and they are less likely to fail or break down or need Much maintenance. For instance, you would need to do a lot more maintenance work when you first get a 100K mile 10 year old Discovery I vs. a 5 year old 60K DII. IMHO
Pete
2003 DII CDL equipped
33" Destination M/Ts
Old 03-10-2009, 04:33 PM   #5 (permalink)
XtremeMarine's Avatar
A 99' DI (last of the breed), or an 04' DII (last of the true Disco's) would be a great choice. Most Disco owners consider the 99' DI the best of the best, but a lot of us DII owners wheel the snot out of our trucks. Pete's a little off base, as the DII is no easier to lift than a DI, but it will stuff a slightly larger tire lift vs. lift than a DI because of the design of it's inner wheel wells, and the flares that come stock. If you try to find a DII, 04' or not, try to get one without ace and sls. You'll want the rear coils instead of air bags if you're going to wheel it. Also, if you can't afford an 04' model, the 99' and 00', and even very early 01' DII's had the nipple on the transfer case for locking cdl. You'd just need to add the shifter. Good luck with your search.
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 03-10-2009, 04:40 PM   #6 (permalink)
a DII requires alittle to no trimming when lifting and fitting larger tires. i have an RTE 2" lift and 33s. no trimming required.
also, take the flares off. they look gay. like that big gay banana on your A-pillar.
michaels is online now   Reply With Quote
Old 03-11-2009, 12:51 AM   #7 (permalink)
Truth > Freedom
Chazz Layne's Avatar
Gallery: 11
I agree with all of the above (except the part about the flares ). I would just add that if you miss your TJ, make sure you get the sunroofs. It isn't quite the same as a doorless, topless Jeep but I've found I like it better (I made just that same switch 5 years ago and haven't looked back).
Chazz Layne is offline   Reply With Quote
LR parts, Disco, RRC TheDirtyRover Land Rover Parts and Accessories 4 11-20-2009 03:29 PM
Should I buy a 97Disco or a Disco II? keroppi Discovery Series I 9 07-21-2009 05:51 AM
My trail-ready Disco I for your stock Disco II chelo Land Rover Vehicles 0 11-18-2007 10:55 PM
Pre-95 Disco Newbie needs more advice pfkb72 Discovery Series I 18 09-12-2005 10:49 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts Land Rover Parts and Accessories 9 05-11-2005 02:25 PM
