Brake Cleaner !!! I cant Recommend that or even consider anyone else using it either.
Brake Cleaner will not only remove the Grease but do long term Damage to your Headliner Material, Brake Cleaner is made with "Acetone" and other "Methanol Solvents" that are designed for Heavy Duty Cleaning of Brake Dust and other Brake Parts.
1) From the Manufacture the Cloth is on about a 16th of a inch thick like a sheet of paper in thickness Laminated (Glued) to a 1/8th inch Foam Backing that makes up your
Headliner.
a) Cleaners like Brake Cleaners with Acetone are too Strong!! and chances of De- laminating the Factory Glue between the Cloth and Foam Backing are fairly likely and costly to take that chance, Considering a New Headliner Replacement may cost as much as $1000 to install. Depending on your make,model & Local market.
MY Recommendations:
I would be contacting a Reliable Detail Shop, someone that is "seasoned" in their Business, not someone that just started a Detailing Business and printed up some business cards and now say's their Detailer.
The products we use are formulated for professional use only and not intended for sale to the general public.
(Make sure you ask for a : (Drycleaning Type Spotter)
If your local here in the Central Florida Market i can Recommend several reliable shops that can help you.
Bill
Reason: spelling
