Old 01-12-2008, 03:01 PM   #1 (permalink)
archaeology_student's Avatar
Gallery: 7
Question 2.25 diesel engine fuel priming after line replacement
Howdy,
Just looking for some help with this. I had to replace a line that started leaking. I pulled it off, and have connected half of the new line.
I am unsure of what's next. Do I try to bleed the line to get the air bubbles out that I can see in the line to the injectors before connecting the other end of the line? Do I connect the line, and then bleed it?
How do I go about bleeding the lines? I read the manual but is not too clear
I have a picture of the fuel filter... what do I need to adjust to bleed the line from the pic?
Thanks in advance
"The use of vegetable oils for engine fuels may seem insignificant today. But such oils may become in course of time as important as petroleum of the present time."
- Dr. Rudolf Diesel, 1912
MSN Blog with LR info and Photos
archaeology_student is offline   Reply With Quote
Old 01-12-2008, 03:41 PM   #2 (permalink)
Gallery: 7
Well, I slackened the air vent screw (the middle screw on top in the pic) and have been priming the system... lots of air bubbles in the line I see... do I keep the screw slackened and keep priming until all the air is gone?
Old 01-12-2008, 04:28 PM   #3 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Yes, get all air out.
Jim Hall
obstacle.” Michael
Old 01-12-2008, 04:59 PM   #4 (permalink)
Gallery: 7
Do i need to slacken and bleed the distributor pump after? Do i loosen the bolt that i coloured the head red on the left with in the diagram below? Bolt 58 in the diagram.
Old 02-13-2008, 12:49 PM   #5 (permalink)
Smokey Mountain Man's Avatar
That banjo bolt on top shouldn't be messed with. But the two small ones on the side of the housing are. Loosen them and keep priming until you no longer see bubbles. That should do the trick.
Smokey Mountain Man is offline   Reply With Quote
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 10:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
From the Fry Tank to Our Gas Tanks? FlyWheel General Land Rover Discussion 7 11-04-2005 07:21 AM
