Does anybody know of the ups and downs of swaping a 4.3 chevy motor into a 75 SIII right hand drive? Is it over the top hard because of the RHD, or is it a pretty straight forward swap with the exception of the motor mounts that will have to be fabricated? Also, are there any adapter plates to mate the 4.3to a series trans, or will I have to swap the trans also?
jimfoo
If it has the same bolt pattern as a V8, there are probably adapters floating around. I don't think anyone is currently making them on this side of the pond though. Better upgrade your axles too.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
I have a LHD and 2 RHD's sitting in the driveway. One of each is without engine in the engine bay right now. I looked in there and don't see any problems which you would encounter doing a motor swap. All steering components in a Series are very well tucked out of the way. In fact the chassis has the mounting plate for the steering box on both sides attached to the frame, so it is easy to see where the differences would be. You should have 0 fitment issues because of your steering. The next street over from me, I am helping a neighbor do a 4.3 Chevy swap into a Suzuki Samurai. So I went over there, and took some measurements. The engine is a little shorter than tha 2.25, so you'll have plenty of room to mount it in. If you cannot find an adapter to a series trans, than I'd just make sure that you use a trans with the shortest bellhousing available, so you don't have to make a custom super-short rear propshaft. Check the suzuki samurai board on pirate 4x4, and the guys over at spidertrax.com for ideas on 4.3's, when it comes to best transfer cases and trans to use with that engine, as that is a very common swap for them.
"In certain places, at certain hours, gazing at the sea is dangerous. It is what looking at a woman sometimes is." - Victor Hugo |
Thanks XtremeMarine, that was very helpful. I have located a 4.3 engine, and now am looking for a bellhousing from a 5 speed trans from a 4.3 motor. I talked to a guy today that seems to think it can be mated up that way, so we will see. Thanks again.
Nut Futzer
had a friend just draw a diagram and give the specs to a machine shop.. they made an adapter plate for him for about a bill.
"Its a beautiful thing the destruction of words" “Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.” - Orwell: nineteen eighty-four, true for Oceania, true for today. |
Nut Futzer
let us know how that works out.
4.3 .. not the best engine.. By far... but they certainly are a dime a dozen.
#9 (permalink) |
The later, last generation 4.3 Vortec's are actually pretty nice. And cheap as hell to fix and modify. For Series truck axles, though, I would limit the mods to a better breathing cam, and a set of headers. Otherwise you'll start breaking stuff easy. Stock 4.3 is over the limit of stock 10 splines, and right on the limit of HD10's or stock 24's.
| Thread Tools | |
| Display Modes | |
| 02 navigation swap | mx3mike | Range Rover P38, Mk III and Range Rover Sport | 2 | 03-16-2008 09:15 AM |
| 150 AMP Alternator 4 Swap into pre 93 SWB RR | hamrendan | Range Rover Classic | 1 | 12-06-2007 07:06 PM |
| 150 AMP Alternator 4 Swap into pre 93 SWB RR | hamrendan | User Ebay Links | 0 | 12-05-2007 10:54 AM |
| Engine Swap questions | ArmyRover | Range Rover Classic | 2 | 10-13-2007 10:01 AM |
| How feasible would a Cummins 5.9 swap be? | Angel of Death | Series Land Rovers | 32 | 11-09-2005 10:44 PM |
