Old 04-29-2008, 04:27 PM   #1 (permalink)
TheWedge's Avatar
Default 4.3 V6 Swap???
Does anybody know of the ups and downs of swaping a 4.3 chevy motor into a 75 SIII right hand drive? Is it over the top hard because of the RHD, or is it a pretty straight forward swap with the exception of the motor mounts that will have to be fabricated? Also, are there any adapter plates to mate the 4.3to a series trans, or will I have to swap the trans also?
TheWedge is offline   Reply With Quote
Old 04-29-2008, 04:57 PM   #2 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
If it has the same bolt pattern as a V8, there are probably adapters floating around. I don't think anyone is currently making them on this side of the pond though. Better upgrade your axles too.
Jim Hall
obstacle.” Michael
Old 04-29-2008, 05:02 PM   #3 (permalink)
TheWedge's Avatar
What if any problems am I going to encounter though because of the RHD?
Old 04-30-2008, 04:33 AM   #4 (permalink)
XtremeMarine's Avatar
I have a LHD and 2 RHD's sitting in the driveway. One of each is without engine in the engine bay right now. I looked in there and don't see any problems which you would encounter doing a motor swap. All steering components in a Series are very well tucked out of the way. In fact the chassis has the mounting plate for the steering box on both sides attached to the frame, so it is easy to see where the differences would be. You should have 0 fitment issues because of your steering. The next street over from me, I am helping a neighbor do a 4.3 Chevy swap into a Suzuki Samurai. So I went over there, and took some measurements. The engine is a little shorter than tha 2.25, so you'll have plenty of room to mount it in. If you cannot find an adapter to a series trans, than I'd just make sure that you use a trans with the shortest bellhousing available, so you don't have to make a custom super-short rear propshaft. Check the suzuki samurai board on pirate 4x4, and the guys over at spidertrax.com for ideas on 4.3's, when it comes to best transfer cases and trans to use with that engine, as that is a very common swap for them.
Old 04-30-2008, 03:53 PM   #5 (permalink)
TheWedge's Avatar
Thanks XtremeMarine, that was very helpful. I have located a 4.3 engine, and now am looking for a bellhousing from a 5 speed trans from a 4.3 motor. I talked to a guy today that seems to think it can be mated up that way, so we will see. Thanks again.
Old 04-30-2008, 06:00 PM   #6 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
had a friend just draw a diagram and give the specs to a machine shop.. they made an adapter plate for him for about a bill.
"Its a beautiful thing the destruction of words"
“Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.”
- Orwell: nineteen eighty-four, true for Oceania, true for today.
zed is offline   Reply With Quote
Old 04-30-2008, 06:14 PM   #7 (permalink)
TheWedge's Avatar
That is my next move if the bellhousing deal don't work out.
Old 04-30-2008, 11:52 PM   #8 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
let us know how that works out.
4.3 .. not the best engine.. By far...
but they certainly are a dime a dozen.
Old 05-01-2008, 04:29 AM   #9 (permalink)
The later, last generation 4.3 Vortec's are actually pretty nice. And cheap as hell to fix and modify. For Series truck axles, though, I would limit the mods to a better breathing cam, and a set of headers. Otherwise you'll start breaking stuff easy. Stock 4.3 is over the limit of stock 10 splines, and right on the limit of HD10's or stock 24's.
02 navigation swap mx3mike Range Rover P38, Mk III and Range Rover Sport 2 03-16-2008 09:15 AM
150 AMP Alternator 4 Swap into pre 93 SWB RR hamrendan Range Rover Classic 1 12-06-2007 07:06 PM
150 AMP Alternator 4 Swap into pre 93 SWB RR hamrendan User Ebay Links 0 12-05-2007 10:54 AM
Engine Swap questions ArmyRover Range Rover Classic 2 10-13-2007 10:01 AM
How feasible would a Cummins 5.9 swap be? Angel of Death Series Land Rovers 32 11-09-2005 10:44 PM
