Old 04-26-2007, 07:26 PM   #16 (permalink)
braganjackson11's Avatar
i have a set of 33x10.50 BFGoodrich M/T's on my 88 that only has the parabolics installed and i actually got more clearance for turning
braganjackson11 is offline   Reply With Quote
Old 04-26-2007, 09:38 PM   #17 (permalink)
Originally Posted by 300bhp/ton
With a good setup leafs will flex well and the YJ Jeep is leaf yet most lift them by 4"+ as a rule.
My son has a jeep. Had to do a 4" lift AND trim the fenders to get 33" tires to fit. That's why there are a lot of Jeep lift kits. His Jimmy had about 3" suspension lift and 3" body lift for 33's.
A Land Rover Series comes stock with 32's and has room to spare. So why do a lift? 1" from Para's, different offset wheels and stuff 34 or 35's under her if you have the money and power.
Greg S is offline   Reply With Quote
Old 05-03-2007, 10:16 PM   #18 (permalink)
archaeology_student's Avatar
Gallery: 7
Talking
Parabolics give a nice lift. Met with Ray at RockyMountain, and saw his 88"... very nice!!!
"The use of vegetable oils for engine fuels may seem insignificant today. But such oils may become in course of time as important as petroleum of the present time."
- Dr. Rudolf Diesel, 1912
MSN Blog with LR info and Photos
archaeology_student is offline   Reply With Quote
Old 05-06-2007, 07:07 AM   #19 (permalink)
Series Moderator
onslow's Avatar
yeah I keep looking around and am still undecided.
Ideally I'd love to go for something like 33.12.50 but these are expensive and not so easy to find in the UK. For a lot less money I can get a much better tread pattern in 265/75R16 or 235/85R16. Possibly a tad too small but I think I'll just have to wait and see. I've got some 33.11.50's on my Discovery and a set of 31.10.50's that Ii can try out and see if they fit, how they look and how they perform.
You can fit up to 35" on a series with extended hangars i ran an 88 with 900x16s them
just get some 1/4 flat bar and make your own thats what my trialler has as did my 88
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
Old 06-10-2007, 12:47 AM   #20 (permalink)
RPGreg2600's Avatar
http://www.difflock.com/buyersguide/...ar/index.shtml
I wouldn't want to put it on my truck, but it definitely gives you a lift.
RPGreg2600 is offline   Reply With Quote
Old 06-11-2007, 03:45 PM   #21 (permalink)
If your looking to make a serious rig, get the gone to far kit and then go spring over axel. yout would need to either flip your wheels some how, or just go with a wider set of axles. If you went with something like a danna 44 or 60, it would be cheaper than buying lockers and stronger axles for a rover casing. the spring over can be done giving you only 4" of lift. and you could twist the diffs up to get ok angles for the driveshafts. it would be an big project but it would be fun. also anything over a 32 inch tire on stock rover axels it going to break all the time, no matter how softly you wheel.
CliftonRover is offline   Reply With Quote
Old 06-12-2007, 01:35 PM   #22 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
You would have to go with cv driveshafts then or have SEVERE vibration and very short u-joint life. Very true about the axle part. I've broken a couple of 24 spline ones, though I have a locker and do play rather hard. Also broken 3-4 fronts.
