» Sponsors
» Sponsors
Old 09-05-2009, 07:42 PM   #1 (permalink)
RogueSeriesIII's Avatar
Default Anybody running bio diesel in a 2.25L?
I've been thinking about running some B99 Bio diesel through my 2.25.
Can you run this fuel without issues? The research I've done does not turn up any info on bio in a 2.25; only later model diesels 200/300tdi. The solvent properties of B99 could prove an issue with the pump, lines or injectors...I'm not sure. Or it could actually help clean out the system, not sure.
My Mercedes 300TD loves the stuff...runs cleaner and has no issues.
Seems like that old 2.25 lump would run on about anything, but it's not worth wasting my diesel pump to find out.
Road rage would cease to exist if everyone drove a 109" 2.25L diesel.
1980 SIII 109" Safari RHD 2.25D w/ OD
1994 RRC LWB 4.2L
RogueSeriesIII is offline   Reply With Quote
Old 09-06-2009, 08:23 AM   #2 (permalink)
Smokey Mountain Man's Avatar
Durring the fuel crunch of the seventys my dad ran a 50/50 mix of diesel and used cooking oil. From what I understand it works but it can gum up the injector pump if it is to cold.
Smokey Mountain Man is online now   Reply With Quote
Old 09-06-2009, 06:46 PM   #3 (permalink)
TerryS's Avatar
I've also been running B99 in my '87 300TD wagon (6 cyl turbo) and recently went for my biannual emmissions test. The guy told me it was the cleanest running diesel he had tested in months. He was shocked when he took the odo reading for the computer, 257K
Old 09-08-2009, 10:46 AM   #4 (permalink)
I hear ya...my 1985 300TD (5 cyl. turbo) has 317,000 miles and runs cleaner and smoother than any other MB diesel I've seen (or smelled). A couple of friends run the 240D sedans and have not had such luck; though they do not seem to be on the same maintenance schedule my vehicels are on..."oh, you have to replace the fuel fileters? Where are they" (Yikes!!) Though...my MB has a heating system for the fuel in cold weather (same tank system that heats the fuel lines and fuel before the pump and also before the injectors). This also makes it compliant for straight waste veggie oil, though it is becoming harder and harder to get free waste oil.
Well enough Benz talk back to Rovers...
Maybe I'll try a 50/50 mix of B99 and diesel and see how it goes...
I have an extra pump in my shop if the bio fuel kills the pump.
Without a heating system on my 109" I will try this before it gets too cold.
I've seen B99 turn to gel at a mere 40°F
I can't be the only guy wanting to run bio fuel in a series 2.25, am I?
Or, are all you guys laughing since I must be the only fool to still be running a 2.25 lump in a 109"?
1994 RRC LWB 4.2L
Old 09-09-2009, 07:52 AM   #5 (permalink)
You are not the only one with a 2.25 Ltr in a 109. I have one. It has a little help though in that I have a turbo set up on it.
Old 09-09-2009, 09:57 AM   #6 (permalink)
Really? Tell me more!
I was looking into that last summer and was repeatedly told that the 2.25 would not withstand a turbo for any legnth of time. Suppliers both domestic and in the UK would not sell me a turbo (with a warranty) for that application since they said it would tear apart the motor in short time. I took this 'expert advice' at face value and dropped the idea...
What turbo did you use? Got pics? How long have you been running it?
I was looking into the 2.5L turbo unit since the manifold is so similar I thought it would be a rather simple mod.
I'm all ears...thanks!
1994 RRC LWB 4.2L
Old 09-10-2009, 02:16 AM   #7 (permalink)
The turbo set up that I am running is one that my dad built. It helps alot in the speed department the only draw back is that it gets very HOT which thins the oil and can cause the engine to sieze. But that can be prevented with an oil cooler. What is your e-mail adress? Mine is roverhud@yahoo.com . I will send you pictures of what I have along with pics of the spare unit. From what I can tell it is part of a kit that Atlantic British used to advertise. If you are interested I could sell it to you.
Old 09-11-2009, 04:54 PM   #8 (permalink)
I've run b99 in my 2.25 (also in a 109) for about a year with no problems. Cold snap last December caused enough gelling to plug the filters, but didn't bother the injectors at all; I just swapped in a some fresh filters and waited for things to thaw out a bit. This winter I'll switch to petro a little earlier...
superstator is offline   Reply With Quote
Old 09-11-2009, 05:31 PM   #9 (permalink)
150 miles so far on a 50/50 blend of diesel & B99 and all is good.
The exhaust also has a much nicer aroma as I sit in traffic or idle the trails.
So far so good...
1994 RRC LWB 4.2L
Running Hot, Running Hot, Running Hot Ian Larsen Range Rover Classic 10 07-02-2009 08:32 PM
Having Trouble staying running apbtpetey Discovery Series I 5 11-27-2006 08:53 AM
Springs for Diesel conversion Richie_asg1 Series Land Rovers 1 03-19-2006 04:26 PM
From the Fry Tank to Our Gas Tanks? FlyWheel General Land Rover Discussion 7 11-04-2005 08:21 AM
