» Sponsors
» Sponsors
Old 10-12-2009, 10:11 AM   #1 (permalink)
Land Rover Lover...LIfe's too short not to own one..
Default ARB lockers for Series 2a?
I have an 88 Series 2a..pretty much stock suspension with a Warn 8274..I have a friend selling arb lockers off his 96 D-1 for a really good deal. I dont want to give these up..What do I need to do to make this work for my series truck? Can I just take the whole diff out of the disco and install into the series or do I need to do more than that?
Or would I better off placing the lockers in my 95 LWB? (cost wise)
Any help would be great..Thanks
oalex5023 is offline   Reply With Quote
Old 10-21-2009, 02:19 AM   #2 (permalink)
Discoverys use 3.54:1 gearing in the differentials. Stock Series is 4.7:1. You could swap diffs (you'd have to do front and rear) but your gearing would be off... and the Discovery also has 24 spline axles, the Series truck much weaker 10 spline.
It can be done, but it's not ideal. The lower 3.54 gearing would be tough on a stock 2.25L petrol. And of course you'd need new axles front and rear. Typically, an ARB setup on a series truck would involve 4.7:1 versions of the locker, with the rear axle being upgraded to 24 spline axles.
It's definitely not plug and play.
Overlander23 is offline   Reply With Quote
Old 10-21-2009, 06:35 AM   #3 (permalink)
antichrist's Avatar
You could swap your Series R&P to the ARB and get 24 spline axles. Series Trek I think makes some.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 10-21-2009, 09:21 AM   #4 (permalink)
so what your saying is that I could take the ARB Disco diff and remove the R&P and install into the series diffs? I need to make a quick decision on whether to purchase these lockers..I'm not planning to use the lockers all the time, so I dont plan to get on it.. Just when I'm in a bad situation.
Old 10-21-2009, 11:37 AM   #5 (permalink)
antichrist's Avatar
Yes, but you can't use them with your stock axles, so factor in that cost as well.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 10-21-2009, 12:11 PM   #6 (permalink)
thanks!! really great information. I will contact Trek 1 for the axles..
How often do you use lockers? 300bhp/ton Off Road 10 04-08-2007 09:11 AM
Lockers Rover Nick Off Road 11 10-16-2005 10:06 PM
1999 Discovery Dark Red w/ ARB AIR LOCKERS bobo456 Land Rover Vehicles 1 09-28-2005 07:22 PM
Lockers....who needs them... roverX General Land Rover Discussion 1 07-25-2005 02:56 AM
Thoughts about the Detroit Electrac Lockers MathewBGoode Accessories 3 04-30-2005 08:20 PM
