Old 11-15-2005, 10:19 PM   #1 (permalink)
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
Default Axel distances?
I am about to redo my whole under carrige.
I will be remiving both axels, and the leave springs. I will have the springs retentioned and will replace all the seals, gaskets, bearings ect on the axels myself.
Then to put all togeter again.
Now the question: How do I ensure that I put the axels in correctly, in ther words not scew so that my landy does a impression of a crab?
Is it as easy as just fitting it to exsiting marks? or should I make my own marks before I take it apart? or is there measurement involved?
Moeras
’74 SIII 88” 345 000 Miles & still going strong!
Reality - an illusion caused by the lack of alcohol in the blood.
Moeras is offline   Reply With Quote
Old 11-16-2005, 05:29 PM   #2 (permalink)
jozg44's Avatar
Every time I've done a spring or axle change on a Series Landy it's simply been a case of undoing the U-bolts, propshaft and spring bolts, removing axles/springs.
To put them back- just put the springs on then attach axle with the U-bolts- an advantage with leaf springs is that they also locate the axle.
I'm not aware of any special way of lining up the axles, and every Landy i've seen have the springs/axle off has failed to do any crab impressions
Jack
1990 Ninety County Station Wagon Diesel Turbo
http://members.lycos.co.uk/threelandrovers
jozg44 is offline   Reply With Quote
