Odd transmission.........help needed!
Greetings,
Need Help with odd transmission!
Still have not found a bottom PTO for my hydrowinch.
I was installing an overdrive in this series iia, when
I took off the hydro winch pto I assumed from the directions that this OD bolted right up to the original transmission. Instructions said two hours, However the shaft on my transmission is longer and wider than what it shows in the book and thus will not accommodate the OD without taking the trans apart and replacing the whole main shaft. Is it possible because It came with this hydrowinch that the trans would have been heavier duty? It obviously is a larger heavier duty transmission in this diesel 88 than is normal. Does anyone know of this transmission and is there an overdrive that fits this one specifically or do I have to hunt a normal trans. This is getting to be to much!!!!!...........and still havnt found the guy with the bottom PTO for the hydrowinch.
Thanks for any help,
John IV
