dual mc
log burner,
Sure, no reason why you can't fit a dual mc as opposed to the single unit, but you might have to make other modifications. If you have the booster, that's good. Do you have the shared reservoir between the clutch and the brakes? If so, you'll have to swap out to a different clutch mc. Also, keep in mind the dual brake mc will need to have new lines, one to the front pair of brakes and one to the single line in the back.
Bogatyr
Current Rover Fleet:
