Old 02-26-2006, 05:45 PM   #1 (permalink)
Default Girling Brake Master Cylinder
Hey Guys,
I have an early Series IIA (sometime around 1963). I bought it recently and went to do the brake work and I noticed the master cylinder is a girling 3/4" bore master cylinder not the standard CV type cylinder.
I'm having trouble bleeding the brakes and I was just wondering if anyone has had experience with this master cylinder or can anyone think of any reason why this wouldn't work as well or better than the CV.
Thanks,
Randy
Last edited by randydief : 02-28-2006 at 07:14 AM. Reason: Added more description to title
randydief is offline   Reply With Quote
Old 02-26-2006, 06:34 PM   #2 (permalink)
Otherwise known as STEVE
I believe the CB type was the standard for the 109- although the 109 'version' of the CB had dual lines for the dual wheel cylinders. The CV type is about 1/3 the cost to replace...
I'm no expert in which is better because I haven't had both, but I know someone who is. I'll ask when I get to work tomorrow.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 02-27-2006, 05:08 AM   #3 (permalink)
Thanks for the reply MuddyOval...
I've discovered through research that people use the girling 3/4 master cylinder when they build racing cars. They were also used on Triumph TR3 and TR4 models, so I can't figure out why it would be any more / less troublesome than the standard cylinder.
BTW, I have an SWB Landy...
Randy
