Old 05-14-2008, 02:58 PM   #1 (permalink)
dsfloyd's Avatar
Question Castrol GTLMA
I know this is the only stuff to use on the old rovers but here is my question. I know I can order it through AB, but a little harder to find at auto stores . I used to buy it at napa but don't have any close any more so I will be checking there soon. I finally came across one that carried it (pepboys) but it has switched to a synthetic. Looking at the bottle it says its been reformulated so I am not sure if this is all they offer now? If so is the synthetic fine for the rubber in the system, or should I just order the older stuff from AB .
'60 Series II 88
'04 Silverado 2500 4x4
'02 Altima 2.5 (Hurts less at the pump)
dsfloyd is offline   Reply With Quote
Old 05-14-2008, 05:58 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
more brake fluid information then you will ever want and some good flaming as well.
Atlantic British tellimg me brake fluid HAS to be Castrol? - DiscoWeb Message Boards
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-14-2008, 08:53 PM   #3 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
I think it depends on how old the seals are in your truck. When I first got my Series, I changed the fluid, not having about using Castrol, and within weeks, the fluid was black. Within 6 months I had to replace the brake and clutch masters and slave seals. The newer Rovers(dweb) and probably newer Series seals are probably a different compound, and less likely to be affected by different fluids.
Jim Hall
obstacle.” Michael
Old 05-15-2008, 01:12 AM   #4 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
's funny .. half the threads say its the low moisture content thats important.. half say its the seals.. I'm running no land rover brand parts in my brakes.. or clutch.
I've never run into brake seals that have been damaged by anything other than age.. Most last well beyond their recommended life.
THe manual talks about changing the hydro fluids for moisture contamination.. not for seal problems. But.. I've seen a few self leveling suspensions SUPPOSEDLY failed for wrong fluids. But they were also rather old.
Its like the GL5 issue.. It may corrode yellow metals and reduce standard transmission life by up to 40%.. quite possibly limiting them to only several hundred thousand miles... rover transmissions excepted. Then again.. the new ones claim to be less corrosive.
"Its a beautiful thing the destruction of words"
“Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.”
- Orwell: nineteen eighty-four, true for Oceania, true for today.
zed is offline   Reply With Quote
Old 05-15-2008, 08:13 AM   #5 (permalink)
dsfloyd's Avatar
Thanks for the replies. The seals are newer as I rebuilt the master, slave, and wheel cylinders a few years back. I have also used other brake fluids in the past without any problems.
'60 Series II 88
Old 05-16-2008, 04:36 AM   #6 (permalink)
Zellers used to sell it.
s3landy is offline   Reply With Quote
conventional or synthetic oil? chrisusvi Discovery Series I 64 04-27-2008 07:49 PM
The Truth About Motor Oil and Our Rovers Disco Mike General Land Rover Discussion 15 10-03-2007 12:42 AM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
what engine oil wayno Range Rover Classic 5 12-13-2006 09:59 AM
Castrol LMA question CanuckIIA Series Land Rovers 0 07-25-2005 11:40 AM
