1973 Series III 88
So, what's the trick to crank starting a Series III with 2.25 Petrol? My starter's installed and working but I thought it would be useful to know how to do it in a jam. Yesterday I inserted the crank, applied the parking brake, turned the ignition to ON, and gave is a wimpy crank. Nothing happened. Before I break someting (or rip off my arms from doing it wrong) could someone give me the 1,2,3 steps for doing it correctly?
Piece of Cake, but one word of caution, crank UP, not down. Put the handle in and if it begins to come up on compression but the handle is already going over the top, back the crank handle up 180 degrees. Where you set your choke (assuming your engine is cold, and it's cold out, is dependant on your own engines state of tune, but I would pull it all the way out, then push in a Teeny bit. A good sharp pull upward, no casper milktoast pull, is all it should take, and if your engine is in good order, it should start on the first crank.
One word of advice, never, ever,ever wrap your thumbs around the handle. Cradle the handle near the tips of your fingers, that way, if it ever kicks back, you do not end up with a 2 broken thumbs or in my case when I first tried it, one broken thumb. Mine is regularily started with the handle (just love the looks on peoples faces when I use the handle to start it and play dumb and say that there is not starter motor in it.....). Athough, I tend to push it over the top (had it kick and slapped the tops of my hands the other way, but will have to rethink that method) using the heels of my hands (once again, becareful of the thumbs....) I can generally get it to start with the first push, hard and sharp, pushing straight across (in line with the length of the bumper, that way, if it does kick, then everything is clear), but since mine has just been rebuilt, it starts with no issues.
The other warning, keep your knees out of the turn radius of hte handle, sounds stupid, but I have seen too man people that have the knee in the way.....
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
finally had a chance to use the crank after my battery died!! First turn and she fired! Next time I used it at a local shopping mall, sure turned a few heads. Even had an elderly gentleman watching that said he had not seen one for Ni on 30 years.
I am impressed! I think it will become a good peice of insurance!. |
#7 (permalink) | |
The only time the crank will not work, is if your battery is too far discharged to create a spark at the plug, so it is really good insurance.
On one of our club outings we were given the following scenario: you're stuck and your battery has gone dead and there is no other vehicle available to give a jump start. How do you restart your engine. What they wanted was everyone to jack up a rear wheel and wrap a tow strap around it and pull it like starting a lawn mower. There was every one jacking up their vehicles and wrapping the wheel with the tow strap. They just stood in awe as all the series guys did was to haul out the crank handles and quickly restart the engines. Needless to say all the Defender and Disco owner were crying foul.
Kevin 1969 SeriesIIa 109 station wagon |
#11 (permalink) |
Anyboy know where I might be able to find a hand crank? My SIII didn't come with one ... guessing maybe the original owner thought he might need it?
2000 Discovery II 2000 Range Rover P38 1995 LWB RRC 1973 Series Buchanan Family Home Rover Alley |
#14 (permalink) | |
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
#15 (permalink) |
A local welding shop can make one up for you as well... it is not hard to make.. just a piece of round stock, with two bends and a hole drilled through with anther peice of round stock thorough that. Mine cost me about $20 labour included...
