Links
Old 02-28-2006, 01:50 AM   #1 (permalink)
Faster than the speed of hound...
GoldRover's Avatar
Default Defender doors on a Series III. How easy?
Has anyone here done this?
Are they a bolt-on swap to a late Series III (1981)? Or does the latch on the body-side need to be swapped to match as well? How about fit? They look to be the same dimensions, but are they? I would think this would be a more common swap if it were as easy as that, although I know the purists really hate that kind of stuff. I'm a bit of a purist, but since mine already has a non-LR engine, how about some roll-down windows and doors I can actually lock? Also, I think the hinges are the same. If it IS all that easy, I recon the really hard part is going to be finding a set of doors that don't still have a Defender attached to them.
Just curious. I thought it would be a nice simple upgrade without changing the outward look too much (normal door handles and one big window).
George
1981 Series III 109 2dr - Holden 186 Straight 6
GoldRover is offline   Reply With Quote
Old 02-28-2006, 02:20 AM   #2 (permalink)
Geobloke's Avatar
George
I don't think your hinges are going to be the same fella! If you can source some 90 or 110 doors with pull up handles they may be a straight swop, however if they are ex-mil they will be sliding windows like a series.
If you can get some later type push button type doors from a defender then you will have to replace the hinges (which also allows you to have defender style door mirrors too) and lock striker mechanisms.
As for are they all interchangable I am reliably informed that they are all the same dimensions.
Personally if I had a series I would keep the 2 part doors, love the fact you can take the tops off in summer!
1992 K-reg 200TDI Defender 90 (Eva)
There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill
Geobloke is offline   Reply With Quote
Old 02-28-2006, 03:01 AM   #3 (permalink)
GoldRover's Avatar
Default Here's what got me thinking...
There's an blue '81 Series III that's had the full Defender treatment for sale.
http://www.landrovercentre.com/stock...and_Rovers.htm
I don't care too much for the front end, but I noticed the doors are a nice touch. I just didn't know how much trouble it would be to do.
The hinges look the same as mine, or at least, too close to tell in the photos.
defender-doors-series-iii-how-easy-door-closeup.jpg  defender-doors-series-iii-how-easy-defender-door-close-up.jpg
Old 02-28-2006, 03:37 AM   #4 (permalink)
Geobloke's Avatar
Yup your hinges are the same fella! Now tha only thing is finding 2 doors and sorting out the stricker plates!
Good luck!
Old 03-02-2006, 01:07 PM   #5 (permalink)
Series Moderator
onslow's Avatar
Default soloution
George
The doors are directly interchangable I used an M10 or 12 bolt through the pillar for the latch for the door (where the s3 striker plate is located) worked great and cheap too
