#46 (permalink) | ||
An amazing journey for an amazing man- Get his book "Herman the German" for more insight into his overland journey. |
#48 (permalink) | ||
that's how I was taught.Quote:
I just wanted to know if there were other options besides LR diesels that worked without much conflict for installing.One nice thing though is that the people who tailgate me back off after a few minutes of diesel clouds being sputtered out ![]() Slow and steady wins the race ![]() |
#49 (permalink) |
the 2.25d is ok, drive slow, be courteous to other drivers, and enjoy the trip.
Did you read this? I know you used to post there: http://forum.landrovernet.com/showth...=perkins+prima |
#50 (permalink) | |
Ian Matthews
I thought this discussion about whther to convert to a diesel or not. It seems to have changed to whether a diesel can compete on a trials course. If you want a diesel that will pull down low, you need to go for something bigger than a 2.5 litre. Should try something at least the size of the Izuzu. |
#51 (permalink) |
Ian Matthews
You can stop the personal opinions, here are the engine specs
Engine> Power (KW/HP@RPM) >Torque (NM/LbFt@RPM)> Weight Rover LR 2.25L Petrol> 52/70 @ 4000> 163/120 @ 2000> 204 Kg / 450 lbs LR 2.5L Petrol> 62/83 @ 4000> 181/133 @ 2000 LR 2.25 Diesel> 45/60 @ 4000> 140/103 @ 1800 LR 2.5 Diesel> 51/68 @ 4000> 158/117 @ 1800 LR 2.5 T Diesel> 63/84 @ 4000> 203/150 @ 1800 LR 200 tdi> 83/111 @ 4000> 198/146 @ 1800 LR 300 tdi> 84/113 @ 4000> 265/195 @ 1800 LR td5 (Def)> 90/121 @ 4200> 300/221 @ 1950 LR td5 (Disc)> 101/135 @ 4200> 300/221 @ 1950 LR 2.4 diesel> 90/121 @ 3500> 360/265 @ 2000 BMW 2.5L 6 cyl (Used in RR)> 100/134 @ 4400> 270/199 @ 2300 2.6L LR 6 cyl (7:1)> 67/90 @ 4500> 178/131 @ 1500 2.6 L LR 6 cyl (7.8:1)> 71/95 @ 4500> 181/134 @ 1750> About 600 lbs dry 3 L Rover passenger 6 cyl (8.75 > 115hp@4500 > 164@1500LR 3.5L V8> 85/114 @ 4000> 251/185 @ 2500> 144 KG / 318lbs LR 3.5L V8 (Stage I)> 68/91 @ 3500> LR 3.9L V8 (US spec)> 136/182 @ 4750> 312/230 @ 3100 LR 4.0L V8 (US spec)> 136/182 @ 4750> 315/232@ 3000 LR 4.6L V8 (94 RR non-US spec)> 157/211 @ 4750> 358/264 @ 3000 Rover/Jag 4.4L V8> 220/295 @ 5,500> 425 / 314@ 4,000 Notes: Rated economy in '06 LR3, L/100km (mpg) : City 20.9 (11.2) Highway 11.6 (20.3) Rover/Jag 4L V6 (petrol)> 160 /250 @ 4500> 360 / 266 @ 3000 Notes: Rated economy in '06 LR3, L/100km (mpg) : City 21 (11.2) Highway 11.9 (20) Rover/Jag 2.7L TDV6> 140/190 @ 4,000> 440 / 325 @ 1,900 Notes: Rated economy in '06 LR3, L/100km (mpg) : City 11.5 (24.6) Highway 8.2 (34.5) Rover/Jag 3.6L TDV8> 200/ @ 4,000> 640 / 325 @ 2,000/ to 2500 RPM (flat curve) Notes: Rated economy in '07 RR Sport, L/100km (mpg) : City 14.7 (19.3) Highway 9 (31.4) with 6 speed auto transmission Santana 4 cyl 2.3L petrol > 51/ 68 @ 4000> 163/ 120 @ 1750 4 cyl 2.3L diesel> 45/ 60 @ 4000 > 139/ 103 @ 1800 6 cyl 3.4L petrol > 77/103 @ 4000> 240/ 177 @ 1500 6 cyl 3.4L diesel> 70/ 94 @ 4000> 207/153 @ 1800 Notes: The Santana 6 cyl design is basically the 4 cyl engines with 2 cylinders added. Nissan SD33 Diesel 6 cyl, no turbo> 70/94 @ 3600> 217/160 @ 1800> 304 KG / 672 lbs dry SD33T Diesel 6 cyl, no intercooler> 105/141 @ 3800> 255/188 @ 2000> 305 KG/ 673 Lbs Notes: SD33 from '76 - '80 International Harvester Scout, SD33T from 1980 only LD28 Diesel 6 cyl, no turbo> 69/93 @ 4400> 200/148 @ 2000 Notes: from '80 - '83 Nissan Maxima Toyota (Land Cruiser engines) B Diesel, 3 L 4 cyl> 57/76 @ 3600> 188/139 @ 2200 3B Diesel, 3.4L, 4 cyl> 63/84 @ 3500> 206/152 @ 2200 3B-T Diesel, 3.4L 4 cyl> 91/122 @ 3400> 285/210 @ 2000 ISUZU 4BD1 (3.9L 4 cyl diesel)> 66 / 86 @ 3200> 245/ 181 @ 1900rpm> 711 pounds dry Notes: 32 inches long, 28 inches wide and about 28 inches tall. 4BD1-T (3.9L 4 cyl Diesel)> 90/ 121@ 3000> 314/232 @ 2200> 721 pounds dry Notes: 31 inches long, 27 inches wide and about 30 inches tall. |
#52 (permalink) | |
Series Moderator
Current fleet 86 90 V8 in bits 86 RR classic Under repair 94 Disco TDI 3dr ex-police 256k and still going 80" coil sprung V8 auto Trialer in progress 71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine Stuff I have had at one time or another 76 S3 LWB 65 2a ex mil swb 71 2a swb safari 67 2a 1 tonne TACR 57 S1 V8 SWB 81 S3 SWB diesel 82 s3 SWB diesel 82 RR 2 dr perkins diesel 83 RR 4dr V8 84 RR 4dr V8 LPG 83 RR 4dr V8 LPG "in vogue" 88 RR gm 6.2 V8 Diesel 89 RR 3.5 mazda TDi 75 S3 LWB stationwagon 75 S3 2.6 LWB 86 110 2.5D 91 disco V8 91 disco TDi 89 disco V8 81 RR isuzu 2.8 TD |
#54 (permalink) |
Ian Matthews
Your right, you can't trust things on the net. But the specifaction seem to change everywhere you look. By my manual the 3.5ltr carbie motor put out 156BHP and 205 Lb Ft Torque.
The 200 Tdi and the 300Tdi did have the same specs in the Discovery, but not in the Defender. The power of the Defender on the 200Tdi was down on the Disco, where in the 300Tdi, they were the same at 111Bhp. The torque is wrong for the 300Tdi, but most of the figures are not too far out. |
#55 (permalink) | ||||
The Best 4X4XFar
A stock TDI makes PEAK torque at around 1800rpm, I’d call that fairly low in the rpms. Also considering a 300Tdi still makes plenty of power and pulls from 1100rpm or lower and that#s in high range under normal road conditions. Due to the torque multiplication factor of low range it’s even less of an issue. Quote:
So a trail would be of no more bother to it. Quote:
Also I don’t think there was a discrepancy with the 200Tdi and output from Defender to Discovery it was also used in the Range Rover as well. But there are no known differences in the engines. 300Tdi’s are slightly different as some Discovery’s had CATS where Defenders didn’t along with EGR and a few of the latter Discovery’s had ECU controlled 300Tdi’s which Defenders never had. Only the TD5 has different outputs but this is mostly down to the ECU although fixing the issue is more complex. Another thing to note, PEAK numbers really don’t mean anything you need to see the profile of the curve to see where it is making its power.
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#56 (permalink) |
The Best 4X4XFar
LR 300 tdi:
113bhp @ 4000rpm 195lb ft @ 1800rpm So at 1800rpm it in stock trim it makes almost as much torque as the 4.0 V8 makes at 3000rpm. The V8 is not likely to be making as much or more torque at 1800rpms. I’d say that makes the diesel very good in the low rpms. LR 4.0L V8 (US spec): 182bhp @ 4750rpm 23lb ft2@ 3000rpm Typically a mildly modified Tdi engine (intercooler & tune) will see around 35% increase in HP/torque. Making: 153bhp PEAK But more importantly 263lb ft and it’ll still make it down as low as 1800rpm. So in the low rpms a 2.5 Tdi engine can not only make more torque than a 4.0 EFI Rover V8 but due to the fact that HP = torque (lb ft) x rpm / 5252 it will also be making substantially more HP at that rpm as well. Another thing to remember is how much power it can make over it’s rpm range. Tdi’s don’t rev much past 4000rpm (PEAK HP) but as they make PEAK torque at only 1800rpm it means their power band is in fact the vast majority of it’s entire rpm range. With a V8 it may make some power down low, but we already know that PEAK torque isn’t until 3000rpm. At the end of the day the Rover V8 in 4.0 litre trim will make LESS power for more of the time. Where the V8 wins out is at WOT the extra rpms available mean that higher PEAK HP can be achieved and ultimately be faster.
#58 (permalink) | |
The Best 4X4XFar
Have you ever driven a Tdi/Td5 off road? What do you consider to be low rev? And what part of my above post do you disagree with? Are you just pissed that you're wrong and are not man enough to admit it?
#59 (permalink) |
Ian Matthews
Yes I have driven Tdi's and TD5s and I go out with the same model vehicles in V8 and diesel form and can compare the differences quite easily. Also go out with and driven diesels in Auto and manual formats and can compare the differences in real life off-road situations.
What I consider low revs is below the turbo cut in. I am not going to go through every point you attempt to make and state why it is wrong. You can have that to yourself. |
#60 (permalink) | ||
The Best 4X4XFar
