#106 (permalink) | |
#107 (permalink) |
Ian Matthews
TerryS, its from that Wikipedia site. Do you want me to get another source?
You can try this: "In a hydraulic torque converter, efficiency depends intimately on the angles at which the fluid enters and leaves the blades of the several parts. Because these angles change appreciably over the operating range, k varies, being by definition zero when the output is stalled, although output torque at stall may be three times engine torque for a single-stage converter and five times engine torque for a three-stage converter. Depending on its input absorption characteristics, the hydraulic torque converter tends to pull down the engine speed toward the speed at which the engine develops maximum torque when the load pulls down the converter output speed toward stall." |
#108 (permalink) |
The Best 4X4XFar
It doesn’t matter what the torque converter does, your motor is NOT making 520lb ft.
The dyno graph is WRONG as it can't compensate for the slippage of the TC. As has already been stated some Dynojet Chassis Dyno's can compensate using winPEP 7 software. If you're motor is fairly stock then it will be making PEAK torque somewhere between 2500-4500rpm depending on specifics and it certainly won't be near 400lb ft, in fact it may even struggle to break much past 300 lb ft
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#109 (permalink) |
[quote=p76rangie]TerryS, its from that Wikipedia site. Do you want me to get another source?[quote]
No, Don't trouble yourself on my account. It's just that, after reading that first quote, I realized it was more than 30 years old, possibly 40 years old. I then began to wonder how this volitile thread went from talking about diesel engines in Series trucks to antique torque converters. |
#110 (permalink) | ||||
Ian Matthews
TerryS, the ZF4 auto is basically 20 plus years old.
300Bhp, are you ever going to read something before you open your mouth. Find where I ever said the motor put out 520ft lb. I always quoted at the wheels. Here I will help you. Quote:
#112 (permalink) |
Ian Matthews
After 10 years in this current stint of 4WDing, too much. That is why I am actually backing off on the driving a bit and getting more involved in other 4WD related activities, like competitions.
You spend all your time and money making the truck better and better to tackle those harder tracks. Then you have to find harder and harder tracks to make it interesting. Then you get to a point where it is hard to find challanging tracks and you end up getting board with doing the same ones over and over. So stick to your standard series vehicles and have fun, as any track is a challange in them. |
#113 (permalink) | |
The Best 4X4XFar
)I feel like creating a whole new user account just so I use them. So lets get this straight, your Range Rover makes more power at the wheels than it does at the engine????? You are so so: ![]()
#114 (permalink) | |||
The Best 4X4XFar
further humiliation:
![]() Quote:
So that means 260lb ft is half the flywheel torque then. Lets see: 260 x 2 = 520 or 100%. So YES you have said your motor makes 520lb ft @ 1600rpm BTW – is this you? ![]()
#115 (permalink) | |
#116 (permalink) | |
Series Moderator
RV8 at 520 ib/ft + ZF4 auto= BOOOOOOOOOOOOOOOOMMMMM!!!!!!!!!!!!! My 6.2 gm diesel used to eat one of these boxes a year and the torque was far less than you claim yours produces
Current fleet 86 90 V8 in bits 86 RR classic Under repair 94 Disco TDI 3dr ex-police 256k and still going 80" coil sprung V8 auto Trialer in progress 71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine Stuff I have had at one time or another 76 S3 LWB 65 2a ex mil swb 71 2a swb safari 67 2a 1 tonne TACR 57 S1 V8 SWB 81 S3 SWB diesel 82 s3 SWB diesel 82 RR 2 dr perkins diesel 83 RR 4dr V8 84 RR 4dr V8 LPG 83 RR 4dr V8 LPG "in vogue" 88 RR gm 6.2 V8 Diesel 89 RR 3.5 mazda TDi 75 S3 LWB stationwagon 75 S3 2.6 LWB 86 110 2.5D 91 disco V8 91 disco TDi 89 disco V8 81 RR isuzu 2.8 TD |
#117 (permalink) | ||
Get in, hold on!
-TsiArt ![]() 1989 Mercedes 190D 1985 Toyota 4Runner 1985 Subaru GL wagon |
#118 (permalink) |
back to the heart of the thread. Does anyone have pics or know of any pics that show the various diesels in the series rovers besides the rover engines (e.g., the 200 tdi or 300 tdi)?
![]() Can't we all just get along, and call it a draw with some ![]()
"The use of vegetable oils for engine fuels may seem insignificant today. But such oils may become in course of time as important as petroleum of the present time." - Dr. Rudolf Diesel, 1912 MSN Blog with LR info and Photos |
#119 (permalink) |
Ian Matthews
This is obviously getting no where. you are attempting to pull at minute threads to justify the stance you took. You obviously have no clue as to how a torque converter works, or at least your not willing to admit it. And yes, at the wheels at low revs, you would need a motor putting out around 500 ft lb torque in a manual to have the equivalent torque at the wheels as my motor and auto. I know that this is a difficult concept for some small brains to comprehend, but it does not change the facts.
and 300Bhp, i love what you have as part of your signature when you post, I get a laugh every time on what you proudly list as a modification to your disco. |
#120 (permalink) | |
You should start another thread so maybe you can get some answers to your question instead of being splashed with urine. I've got a Mercedes 2.4 diesel in my truck and it's great. I even sell an adapter kit to help get it in there. Start another thread and I'll tell you all about it. Jim |
