Old 03-19-2008, 06:31 PM   #1 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
Default fairey overdrive noise.. what's normal
I engaged my fairey overdrive for the first time today, trying to keep up with traffic. (unsuccessful
It sounded pretty loud.. darn geary... lot of noise..
Since I read that people like them to REDUCE noise.. I was wondering it that was ok.
I haven't checked the fluid.
It definitely did what it was supposed to. dropped my rpms tons..
But with a slipping clutch.. and the grinding.. it wasn't worth it. I just got off the highway..
zed is offline   Reply With Quote
Old 03-19-2008, 07:45 PM   #2 (permalink)
KevinNY's Avatar
They do make a good bit of gear whine. Keep it topped off and use some lucas oil treatment (up to half) to quiet it a bit.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
KevinNY is online now   Reply With Quote
Old 03-19-2008, 07:46 PM   #3 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Better get used to checking the oil regularly. The more they wear, the noisier they get, especially if they run low on oil.
Jim Hall
obstacle.” Michael
Old 03-19-2008, 07:59 PM   #4 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
Roger..
I'll check it. I assume you just pop off that inspection plate.
Old 03-19-2008, 08:14 PM   #5 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Should be a dipstick on the side, although I'd overfill it just a little bit myself.
Jim Hall
obstacle.” Michael
Old 03-20-2008, 09:58 AM   #6 (permalink)
XtremeMarine's Avatar
Get used to checking ALL fluids, more often than regularly. That seems to be the norm with Series trucks.
Old 03-26-2008, 11:13 PM   #7 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
Dip stick is only on the old ones i read. Mine has a HEX where I see old ones have dip sticks.
Old 03-27-2008, 07:04 AM   #8 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Well, I'd think there must be a dipstick on the hex bolt then, otherwise there is no way to tell how much oil it should have unless it has a fill level bolt in the side.
Jim Hall
obstacle.” Michael
Old 03-27-2008, 07:21 AM   #9 (permalink)
KevinNY's Avatar
If there is not a dipstick on the hex then someone lost the original, call RDS for a replacement if you need it.
Old 03-27-2008, 05:13 PM   #10 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
Oh.. i didn't take the hex out yet. I took out the trans and all.. so it got drained and removed.
Old 03-30-2008, 05:52 PM   #11 (permalink)
pickuprover's Avatar
Thought you might be interested in this site Zed stage1v8.net - Manuals if you look on the second column, you might just see something very interesting to you....
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 03-30-2008, 10:31 PM   #12 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
hmm I have most of those.. I got the manual for the overdrive from rovers down south and the repair manual from that south african sight in "handy links" thread.
One thing I would love is an owners manual..
Operating a Superwinch (Fairey) Overdrive Jayce Series Land Rovers 20 05-26-2007 07:54 PM
Urgent need parts for Fairey Overdrive FrankS Australia / New Zealand 2 07-06-2006 03:55 AM
URGENT, Fairey Overdrive Parts Wanted FrankS Series Land Rovers 7 07-05-2006 07:29 AM
Squealing Noise on Startup -- Viscous Fan? Oconee Disco Discovery Series I 3 09-14-2005 08:08 AM
Overdrive wine? Butternut Series Land Rovers 7 06-29-2005 01:38 AM
