Old 03-11-2008, 03:41 AM   #1 (permalink)
Nilhan WeeraSinha's Avatar
Question Fitting Defender Axels & Diff on a S111
Hi,
Is it possible to fit complete Defender axels (front and rear) complete with Diffs on a S111 ?
I intend retainng the leaf springs.
What obstacles will I have to overcome?
Prop Shaft length to be shortened?
Regards
Nilhan
Nilhan WeeraSinha is offline   Reply With Quote
Old 03-11-2008, 04:55 AM   #2 (permalink)
pickuprover's Avatar
Front axle, all the steering components have to be modified.
Axle casings have to be reinforced to accept the leaf springs (no mounts on the defender axles), remove the mounts for the coils, install shock mounts on the casings....
Rear axle, remove sway bar fittings.
And that is just what I can come up with off the top of my head.
What is the purpose of this? if you are going to put defender axles under, most do it so they have coils, not just leafs. If it is for the disc breaks then you probably would be better going with a disk brake conversion (ROcky Mountain makes one)
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 03-11-2008, 07:38 AM   #3 (permalink)
gordo's Avatar
also the gearing will be taller and the axle is wider so it may require some trimming. Gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
Old 03-11-2008, 10:21 AM   #4 (permalink)
I have discovery axles on my 200 tdi IIA 109 sw. I cut all the brackets off the axle tubes, and welded spring perches for a dana 60 on. the shock mounts need to be added to the rear axle on a 109 but otherwise your all set. The drag link needs to be either lengthened 2" some how. i just unthreaded the ends a little. And the tie rod needs to be have the steering dampener mount cut off, and the rod its self has to be bent slightly to clear the leaf springs. Other than that enjoy the disc brakes and stronger axles. If you have a stock engine you should change gearing.
CliftonRover is offline   Reply With Quote
Old 03-11-2008, 02:11 PM   #5 (permalink)
MISSING THE HELL OUT OF SEATTLE
Series 3 guy's Avatar
Gallery: 5
Hey there! 200tdi? Brilliant,I am looking at this very conversion at the momment. Do you have any pics as I would love to see yours?
Missing you Dime.You were taken from us too early my Brother.
82' series III 109 safari prepared 2.25 pet.WILL NEVER GET RID OF!!!!!!
91'Range Rover classic 3.9L V8! I LOVE IT!!
98' Land Rover Discovery with a MOD wolf 300 tdi(sold)
97' Defender 90 300 tdi (sold)
97' Range Rover 4.6L V8(sold)
Series 3 guy is offline   Reply With Quote
Old 03-12-2008, 07:48 PM   #6 (permalink)
roversam96
I am in the middle of a hybrid build and am using toyota axles in mine it has the width as the rover you may want to look into that as an option
roversam96 is offline   Reply With Quote
Old 03-13-2008, 12:44 PM   #7 (permalink)
I have pics but not at school, I will get them this weekend. The engine is definatly worth the money. the onl;y mount you have to change is the RH front. this mount needs to be a lower. then remove the battery box mount, fabricate new radiator and inter cooler mounts, cut the back off the radiator support, use a electric fan (I never need turn mine on), and space the steering box out 3/4 of an inch away from the turbo down pipe. The disco axles are definatly worth it, but with the lower 200 tdi eninge mount you need longer front shackles. then your all set.
Old 03-14-2008, 11:18 PM   #8 (permalink)
Newbie
Default Lockers
Did the Disco axles come with a factory locker option?
JMFL is offline   Reply With Quote
Old 05-30-2008, 01:18 AM   #9 (permalink)
Hi Roversam96
Could you please specify the model type of the Toyota axels
Thanks
Nilhan
Old 05-30-2008, 04:21 AM   #10 (permalink)
msggunny's Avatar
Gallery: 5
Mini truck or Cruiser axles.
This is the way to go,
Cheaper
Stronger
More gear ratios avialable
More traction options (Lockers)
There is even a conversion you can do for series and coiler axles to use the same tubes but toyota internals.
I dont know the feesability for you Nilhan since the shipping for the kit to Sri Lanka would be expensive, but i know they have toyotas galore over there.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
When god gives you lemons, find a new god....
msggunny is offline   Reply With Quote
Old 05-30-2008, 06:28 AM   #11 (permalink)
Rebuilding Rover
ArmyRover's Avatar
nope that would have made things way to easy for us
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-30-2008, 12:56 PM   #12 (permalink)
roversam96
i am using 1979 toyota axles out of a mini truck the best part is they are cheap and there are parts just about everywhere in the world
RoverSam
Old 05-31-2008, 11:04 AM   #13 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
but now-a-days.. everyone wants toyota axles, and junk yards aren't keeping the parts they used to. People tend to think they have something special and charge for it.
Luckily a vehicle with a crappier frame than a land rover was the toyota pickup till the tacoma or so ~94 ish. So there's a lot of busted ones out there. That everyone wants for their isuzu and geo swaps.
And it would be a shame to kill an FJ for its axles.
"Its a beautiful thing the destruction of words"
“Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.”
- Orwell: nineteen eighty-four, true for Oceania, true for today.
zed is offline   Reply With Quote
Land Rover Defender 110 SVX earmarked for Australia Administrator Land Rover News 2 01-21-2008 12:01 PM
New Defender out in March!!!! 300bhp/ton Defender 10 02-16-2007 06:47 AM
Front Diff Searcaigh Discovery Series II 2 02-17-2006 03:26 PM
British To The Core - The Land Rover Defender Serg General Land Rover Discussion 1 01-12-2006 10:57 PM
Fitting Speakersin a Defender 110 vinnie Defender 4 03-16-2005 02:59 PM
