Old 07-25-2005, 01:18 AM   #1 (permalink)
Default Fitting Overdrive
Hi Guys
I have an overdrive unit which I have tried to fit previously. My big problem was trying to remove the 4th gear. There is a special nut which looks like the front hub nut in a way, which I need to get off.
Does anyone know what tool is needed to get this nut off, or what alternative tool or homemade tool that can be used.
I would really like to get this fitted. I have had to overdrive unit for about 5 months already.
Thanks
Jayce
Jayce is offline   Reply With Quote
Old 07-25-2005, 06:58 AM   #2 (permalink)
Bogatyr's Avatar
Jayce,
Yeah, there is a castle nut on the mainshaft which has to come off. I belive there is also a lock washer on there...
I know Rovers North here in the US sells a tool that will fit that nut exactly, last I checked it cost $38USD or so...but, I'd think that would beat the old trying to get the thing off with a chisel trick.
I'm sure this tool must be available in other places. You might want to drop by a rover shop and see if one of the guys there would lend you the thing for the weekend in exchange for some beer...
Bogatyr
Current Rover Fleet:
Old 07-26-2005, 12:21 AM   #3 (permalink)
Dear Bogatyr
Thanks for the advice, you may have unwittingly given me the idea of using a chisel!!!!!!
However I must admit that is makes my insides churn a bit. Well at least I have part of the equipment, a 2 pound sledge hammer called Fred and an equally well equippend rubber mallet called Lucy. I must just get a Chisel............ I think I will name it Spike.........however I might just look for the real deal.
cheers
Jayce
Old 07-26-2005, 07:29 AM   #4 (permalink)
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
Yeah And I've got a Angle-grinder called Jaws......
Moeras
’74 SIII 88” 345 000 Miles & still going strong!
Reality - an illusion caused by the lack of alcohol in the blood.
Moeras is offline   Reply With Quote
Old 07-26-2005, 07:44 AM   #5 (permalink)
Super Moderator
Disco's Avatar
What do you call the hammer when you hit your thumb?
Old 07-26-2005, 07:57 AM   #6 (permalink)
Profesional Hunter
F*&#@$%ng Fred !!!!!
Moeras
